Old 18th November 2005, 11:22 AM   #1
EC8010 is offline EC8010  United Kingdom
EC8010's Avatar
Default Is baffle step loss phaseless?
Because if it is, then using an electrical equaliser (LR, CR, etc) will correct the amplitude response but upset the phase response. My gut feeling is that baffle step loss is phaseless (just like aperture effect), but is there an acoustics whizz out there who can give a definitive answer?
The loudspeaker: The only commercial Hi-Fi item where a disproportionate part of the budget isn't spent on the box. And the one where it would make a difference...
Old 18th November 2005, 12:07 PM   #2
MJK is offline MJK  United States
No, baffle step loss is not phaseless. Adding a filter improves both the magnitude and phase associated with a baffle step loss. If you look under the General Speaker Related Articles link on my site, and look at the baffle step calculation document you will see both the magnitude and phase plots for a square baffle sample problem.
Hope that helps,
Old 18th November 2005, 01:24 PM   #3
soongsc is offline soongsc  Taiwan
soongsc's Avatar
Baffle diffraction caused by baffle step is best solved by the baffle itself. This is because it is acoustically generated wave mixed into the original signal like a mixer. If you mix two signals together electrically, there is no way you can unmix it to create the two original signals. Same with acoustic waves. You may be able to correct it so that it looks good in the FR, but may not sound correct, just different.
Hear the real thing!
Old 18th November 2005, 01:35 PM   #4
EC8010's Avatar
Should have looked there first... Thanks for that.
soongsc: I'm hoping to minimize baffle step loss in the first place...
Old 18th November 2005, 01:36 PM   #5
I think the original question was about baffle step and not baffle defraction. I agree with your statements about baffle defraction but I don't know how to solve baffle step without a very large baffle or a filter of some form (either stand alone or as part of the crossover). I tend to look at baffle step and baffle defraction separately.
Old 18th November 2005, 02:16 PM   #6
EC8010's Avatar
Default Two for the price of one!
I hadn't got to the stage of considering whether diffraction at the edges was phaseless. To minimise baffle step, I plan to make the loudspeakers as thin front to back as possible, have quite a large frontal area, slope the sides at a 45 degree angle, and hang them directly on the wall.
Old 18th November 2005, 02:30 PM   #7
Sounds like a plan. The only potential down side might be the excitation of room modes.
Old 18th November 2005, 03:04 PM   #8
EC8010's Avatar
I'm constrained by WAF and not even sure that this plan will gain approval, so room nodes are the least of my worries...
Old 18th November 2005, 04:38 PM   #9
SY's Avatar
Beware the dread bounceback, especially if you have a light cone. I had a terrible time straightening out the response of an early attempt at an MTM until it hit me that the interference dip corresponded very well to the distance front-to-back of the cabinet.
BTW, a useful way to look at the diffraction dip is to analogize it to a filter made by mixing a direct signal with a time delayed one.
“Listening to records is like ****ing a picture of Brigitte Bardot.” - Sergiu Celibidache
Old 18th November 2005, 04:51 PM   #10
EC8010's Avatar
I don't plan to make it easy for myself - it will be a light paper cone. Some diffusors around the back of the magnet may be in order.
Good thought. That makes it easy to conceptualize.
Does open baffle suffer from baffle step? 454Casull Multi-Way 15 19th May 2012 03:12 PM
baffle Step rgrayton Full Range 33 4th December 2004 11:16 PM
baffle step LOSS? madinoz Multi-Way 28 13th March 2004 10:32 AM
baffle step loss compensator bbaker6212 Multi-Way 1 13th November 2002 10:25 PM
Page generated in 0.19374 seconds (45.14% PHP - 54.86% MySQL) with 10 queries
