Old 18th November 2005, 05:49 AM   #1
tubenut is offline tubenut  South Africa
tubenut's Avatar
Default Super Tweeter Cross Over.....
I am trying to use a Foster Ribbon Tweeter as an add on super tweeter like Tannoy/Townsend/Murata/Elac....
I have been playing with simple 1st order cross over with cap and resistor in series crossing over at points between 10 and 15 kHz. The results are interesting but everytime I wish to change the x over frequency or level it affects both R and C components.
Would an L Pad feeding a cap in to the tweetwer not be better?
How do I calculate the L Pad for matching 84 dB sensitivity speaker system to a 92 dB tweeter of 8 Ohms crossing at "X" frequency?
I did comms electronics a long time ago and can probably work out a pad with supposed input and output impedance of 8 ohms but is that what is required? Would the pad need to do 6 dB as the cap will do another 2dB? (92-84=8 dB)
Old 18th November 2005, 08:22 AM   #2
In most cases yes it would. Could use an adjustable 8R L-pad.
Its generally agreed ribbons don't like 1st order crossovers at all,
due to excursion increasing down to its resonant frequency, the
excursion stays ~ constant with 2nd order, decreases with 3rd.
/sreten.
Old 19th November 2005, 06:27 PM   #3
tubenut's Avatar
X over for ribbon I am using should be 6400 Hz at lowest so thought 11k first order should be safe......
G
Old 21st November 2005, 02:28 PM   #4
DeonC is offline DeonC  South Africa
DeonC's Avatar
Default Try dual first-orders
Hi tubenut
I read somewhere than one manufacturer uses a cap in each leg of the tweeter. Basically the effect is that you get a 2nd-order roll-off with the low phase deviation and other advantages of a 1st-order XO (or so they said anyway). If this is true, this is something you might try.
Enjoy,
Deon
Reality is not digital, an on-off state, but analog.
Terry Pratchett - Moving Pictures
Old 21st November 2005, 03:22 PM   #5
I think the cap most come before the L-pad, og am I wrong !!!
Ole
Old 24th November 2005, 08:19 AM   #6
Default Re: Try dual first-orders
G
you can probably use a first order crossover as long as it is fed from the tweeter terminals.
Originally posted by DeonC
Hi tubenut
Enjoy,
Deon
As described you would not get a 2nd order roll-off.
Ole
Normally the capacitor should precede the L-pad to prevent bass frying it,
if the supertweeter is fed from the tweeter terminals its not so critical.
/sreten.
Old 25th November 2005, 01:34 AM   #7
Mark Techer's Avatar
Send a message via ICQ to Mark Techer
Default Attenuation Network
Try this -
Rp = 10^A/20 x Rt/(1-10^A/20)
Rs = Rt-(1/Rp+1/Rt)^-1
Where
Rp is the resister in parallel
Rs is hhe resister in series
Rt is the rated tweeter impredance in ohms
A is the amount of attenuation needed in negative dB
Hope this helps...
Mark
CIH Explained
Where do I cross this tweeter over? G Full Range 3 3rd April 2009 05:42 AM
Need Cross sch opera super pavarotti stavros Multi-Way 0 19th April 2006 03:12 AM
How low can I cross my tweeter? GuyPanico Multi-Way 1 7th November 2005 02:19 PM
How can I emphasize the super-highs (10k+) with the cross-over ? Blitz Multi-Way 9 1st September 2003 12:51 AM
Page generated in 0.11115 seconds (78.08% PHP - 21.92% MySQL) with 10 queries
