Could any problems be caused by sticking a resistor in series with a Tweeter as opposed to an L-Pad? Apart from impedance, what are the differences?
#2 |
Different impedance is enough to hose your crossover curve: that might qualify as a problem.
#3 |
Do it all the time instead of L-pads but you have to allow for the added resistance and recalculate the crossover at every change.
There's a good section on it in the LDC by Vance Dickason section 7.60.
No longer DIY active |
#4 |
Why do you not want to have an l-pad in the crossover. Resistors are cheap, so I don't see any reason to not use an l-pad.
The power of Science compels you! |
#5 |
Thanks, i have no problem with L-Pads i was just curious
#6 |
over time, & get scratchy; you probably won't change the setting much after the initial excitement of playing with your new creation; resistors are cheaper.
I have an old pair of Sansuis given to me because the previous owner thought they were faulty; I just replaced the L pad with a resistor & have a excellent pair of speakers for the price of a couple of resistors. Pete McK |
#7 |
That parallel resistor adds a bit of electrical damping... Considering the price of resistors, not the exotic sort, I'd say go with L-Pads.
Crossover/Subwoofer Simulator |
| tweeter attenuation on Vifa XT question? | fazman | Multi-Way | 1 | 31st August 2005 09:35 PM |
| help with tweeter attenuation | toenail | Multi-Way | 2 | 14th May 2003 08:20 AM |
| L-pads and variable tweeter attenuation | toenail | Parts | 4 | 14th April 2003 09:34 PM |
| -14 dB tweeter attenuation ? | kristijan-k | Multi-Way | 2 | 20th September 2002 09:22 AM |
| tweeter attenuation | bostarob | Multi-Way | 11 | 22nd May 2002 03:33 AM |
| Page generated in 0.09635 seconds (70.04% PHP - 29.96% MySQL) with 10 queries |
