| Home | Forums | Articles | Gallery | Blogs | Register | Donations | FAQ | Calendar | Search | Today's Posts | Mark Forums Read | Search |
Thread Tools |
Can someone recomend a mini monitor that use a 4in. woofer?
Troels has a design but I think the woofer in his project is no longer in production |
#2 |
Cal Weldon Consulting |
#3 |
I'm thinking of trying the Aurasound NS4-255 with some nice tweeter. They should work well in a tiny box. WinISD gives f3=65Hz, f6=54Hz in a 0,092ft^3 / 2,60 litre reflex at 57Hz.
#4 |
I'll second Cal's suggestion to go with a CSS WR125 or the FR125. The WR is a wide range and needs a tweeter, the FR is full range and doesn't. Lot's of documentation for these on this forum.
Best Regards, TerryO
"If you have to ask why, then you're probably on the right track." quote from Terry Olson's DIYaudio Forum application |
| Thread Tools | |
| Accuton Mini Monitor | stvnharr | Multi-Way | 1 | 28th March 2009 10:04 AM |
| Suggestions for a Mini-Monitor Build | jeffmoore17 | Multi-Way | 4 | 30th December 2008 04:07 PM |
| JGs Mini Monitor - additional questions | Benny the 2. | Multi-Way | 9 | 13th May 2005 12:27 PM |
| The A4 monitor, best mini monitor? | KURT | Multi-Way | 5 | 26th April 2005 01:34 PM |
| Mini-Monitor Project Going On | gary f | Multi-Way | 29 | 20th March 2004 03:45 AM |
| Page generated in 0.06766891 seconds (73.45% PHP - 26.55% MySQL) with 10 queries |
