Question about a speaker HELP
Old 15th November 2005, 06:11 PM   #1
Little.AMP is offline Little.AMP  Yugoslavia
Question Question about a speaker HELP
Hello 2 all you guys
First, sorry for my bad english
Have you heard about SAL speakers? Their home page is
Well, I got 2 of their speakers SBX1620 and I want to make a 2 way bass-reflex speaker box. I have used WinISD Pro, but I'm unsure about box volume and port. I will use it with my little stereo LM1875 amp 2x 25W, which, also has an variable high pass butterworth filter 20-100Hz, 12db/oct. My goal is f3 to be something like 50-60Hz. Here is the data about the driver SBX1620:
Music power : 80W
Power rating : 50W
Impedance : 8 ohm
SPL (1W/1m) : 86,6db
Voice coil former : Aluminium
Cone : Kevlar
Magnet weight : 20oz
DC resistance : 7,4 ohm
Eff. cone area : 136,8 cm^2
Cone Diameter : 13,2 cm
Speaker diameter : 16,7 cm
Free air resonance : 44,07 Hz
Qms :4,46
Qes : 0,675
Qts : 0,586
VAS : 20,97 L
Moving mass Mms : 16,51g
Mech. resistance Rms : 1,11 kg/s
Suspension compl. Cms : 0,79 mm/N
Force faktor BxL : 7,08 Tm
Voice coil inductance : 1,55mH
Maximum linear excursion : Not given
Is this speaker worth of anything, according to thata given? If yes, then what values you would chose for Vb and Fb?
Any suggestions?...
Thank you in advance
Old 15th November 2005, 06:15 PM   #2
richie00boy is offline richie00boy  United Kingdom
Did it Himself
richie00boy's Avatar
Qts is quite high so would be suited to a sealed box. But you might be able to use a QB5 alignment as your amp has a high-pass filter, which might be good. See sound.au.com articles section for more info on using this alignment. You may find help on the forum there as well.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, modules and more.
Question about a speaker HELPHide this!Advertise here!
speaker question space2000 Solid State 1 11th May 2008 04:18 AM
Old Speaker question Cxrazy Everything Else 1 27th December 2007 12:08 PM
Speaker + Amp Question? RXPike Car Audio 7 12th September 2007 11:41 PM
old speaker question, bullet midrange question & link to speaker project wallijonn Multi-Way 10 5th November 2002 06:03 AM
