Old 15th November 2005, 02:52 PM   #1
Send a message via Yahoo to mr_push_pull
Default Is this kind of bracing ok?
My box will be approx. 15x25x40 cm (internal dimensions), and the bracing like shown in the pic (W is woofer, T is tweeter, P is port, B is bracing).
My question is: is it OK to have the horizontal braces very close to the upper and lower walls, won't this create a helmholtz effect? The distance to the walls will be approx. 3 cm.
And if you're thinking that the middle brace will obstruct the air flow, I'll either drop it or cut a hole into it.
Thanks.
Old 15th November 2005, 02:56 PM   #2
Did it Himself
richie00boy's Avatar
You would be much better just making one shelf that runs perpendicular to the walls with cutouts for airflow. Those side parts are serving no purpose in strength as they are so close to the walls. And yes I suspect they will turn your box into a bandpass box.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more
Does A Box Like This Need Bracing? sdclc126 Subwoofers 10 12th May 2006 01:31 AM
Enough bracing? Vikash Multi-Way 51 8th May 2006 05:58 PM
how much bracing is enough gwgjr31 Subwoofers 1 5th May 2006 06:57 AM
do I need bracing for a 15L BR? RockysDad Full Range 12 11th August 2005 07:18 PM
enough bracing?? Chris8sirhC Multi-Way 3 31st January 2004 08:16 PM
Page generated in 0.07719 seconds (70.82% PHP - 29.18% MySQL) with 11 queries
