Old 12th November 2005, 07:26 PM   #1
sachi is offline sachi  United States
Default FE108EZ or VIfa PL11-MG09-08
Hey guys,
I want to know as to which of these two drivers would be best for use as a midrange. I will be using Peter Daniel's LM4780 in parallel mode per driver(midrange) in an active 3 way.
The Fosetx FE108EZ
Vifa PL 11-MG-09-08(would prefer the MH version but doesn't seem to be available anywhere in the US)
The xover points are 350 hz and 3400Hz.
The Fostex being 85$(the VIfa 35$) is it worth going for it considering that i will be using a chip amp and limiting it to those freqs.
For the highs i have a Vifa D27 tweeter and for the lows i have a Dayton 10 inch Classic.
The reason am particular about these two are because i need the outer flange to be between 125mm and 128mm(circular only).
would be great if u can recommend any other drivers with the same dimensions for the above application.
Your opinions would on this would be very much appreciated.
Sachi
Old 12th November 2005, 07:39 PM   #2
Oh..just wanted to mention that the driver would go into a 5L sealed enclosure.
Old 14th November 2005, 05:19 PM   #3
Compared to the Fostex FE-108EZ how does this scanspeak measure up as a midrange.
http://www.madisound.com/cgi-bin/ind....9378&pid=1157
Sachi
Old 15th November 2005, 10:00 AM   #4
maiky76 is offline maiky76  France
Hi!
Take a look at this:
http://www.aedio.co.jp/sokutei/y2k08/mg10sd09.htm
The Fr is way smoother that the Fostex's!
Maiky76
L-pad for FE108EZ wixy Full Range 1 17th May 2008 03:15 PM
FE108EZ and FE168EZ LilMik Full Range 21 21st September 2006 08:37 AM
FE108EZ or 168? vexator Full Range 12 7th January 2006 02:49 PM
FE108EZ as a Midrange audioferret Full Range 18 15th November 2005 05:04 AM
Vifa PL11 in small floorstanding Hilko Peter Multi-Way 4 15th September 2004 12:31 PM
Page generated in 0.07962 seconds (70.59% PHP - 29.41% MySQL) with 10 queries
