Old 12th November 2005, 05:45 PM   #1
Grahamt is offline Grahamt  Canada
Grahamt's Avatar
Default Surround speaker advice/links
I'm starting a little di/bipole surround speaker project. I haven't been able to find very much information on how to design them.
If you have and advice, or can point out any links or other references it would be appreciated.
Here is the progress so far: http://htguide.com/forum/showthread.php4?t=16404
Thanks.
Ingenium Audio
Old 13th November 2005, 08:07 PM   #2
Paul W is offline Paul W  United States
Paul W's Avatar
Graham,
With your room layout, I think you're absolutely right about wanting a more diffuse sound. Maybe two pairs of the GR speakers spread across the back wall...then experiment with phasing within pairs???
Paul
Old 14th November 2005, 01:50 AM   #3
Grahamt's Avatar
Hi Paul,
That's a really good idea, hadn't thought of that. But I think I'll just build a pair for now. I could experiment with that by making that pair the middle surround channel in a 6.1 system, and putting one of them out of phase.
Thanks for the suggestion.
Ingenium Audio
Old 17th November 2005, 03:35 PM   #4
dbrown is offline dbrown  United States
Default Some info
I did some analysis of how surround speakers work when operating as dipoles and bipoles, several different configurations, mounted on the wall.
http://users.d-web.com/dbrown/htdesign/htdesign.htm
Ended up building this. I call it the dB1661 and it's set up to operate the tweeter as a dipole or bipole, switchable.
http://users.d-web.com/dbrown/db1661/db1661.htm
Dave
Old 17th November 2005, 03:47 PM   #5
Grahamt's Avatar
Hi Dave,
Thanks for the links. Someone already pointed those out to me, very interesting results.
I decided to go with a similar design to the GR research surround speakers. I think they will fit my needs the best.
Graham
Ingenium Audio
DIY Surround speaker : please help cmsajith Multi-Way 11 3rd November 2008 09:54 PM
Advice Needed On Dipole/Bipole Wal Mounted Surround Loudspeaker philiprst Multi-Way 9 7th October 2008 06:51 PM
Designing a rear surround speaker pjpoes Multi-Way 7 4th February 2007 12:33 AM
Any consensus on surround speaker format? David Gatti Multi-Way 4 2nd April 2005 05:09 AM
speaker links arcgotic Multi-Way 1 11th November 2004 01:17 PM
Page generated in 0.08958 seconds (75.98% PHP - 24.02% MySQL) with 10 queries
