#2 |
Very cute
/U. |
#3 |
Thanx !
#4 |
Very nice! Did you vapor the veneer?
#5 |
I had to soak it i water.. Filled up my bathtub and let it soak in for 20 minutes or so.. and it worked
The veneer is jakaranda 0,4 mm thick so it is veeeery fragile.. /Z |
#6 |
Oh yeah, and then glued on I guess? How did you fix it? Looks really great.
#7 |
yepp. just glued it on.. i just "rolled" the cabinet on the veneer and put pressure with my bodyweight.. Rolled it back and forth..
No problem, worked lika charm.. the glue i used is called .. mm.. don,t know the eglish word. Contact glue ? well.. i put the glue on,, waited for 10 minutes or so and then just pressed it on.. i keap pressing for about 30 minutes ( rolling it ) Sry for the poor explanation.. |
#8 |
Cool, seemed to work
#9 |
hello zei , how you have calculated the box volume??
#10 |
Hi.
To get the correct volume with curved walls AutoCad was used. Actualy i did not do it myself but a friend did it for me.. it took him about 2 minutes. With the right software and friends it is very easy. Regards Z |
| Zaph's 'all metal system' questions | Ryan_Mc | Multi-Way | 10 | 10th February 2009 07:48 PM |
| Single driver best FR Project/Design | eeyore | Full Range | 10 | 23rd May 2007 03:55 PM |
| zaph's Hi-Vi B3S single driver modded? | Scott_fx | Full Range | 6 | 10th February 2007 02:21 AM |
| Simple, Inexpensive, yet Decent Full Range/Single Driver system? | dsavitsk | Full Range | 11 | 16th August 2006 10:40 PM |
| The Filter design for Zaph,s Hi-Vi B3S single driver system | zei | Multi-Way | 5 | 25th October 2005 08:00 PM |
| Page generated in 0.10627 seconds (77.82% PHP - 22.18% MySQL) with 10 queries |
