Spider surgery - anyone?
Hello,
I'm considering cutting slits in the spiders of my GR165 woofers used in a MTM TL to lower Qts (they are out of spec, bass is a bit boomy).
Qts has to be lowered from about 0.64 to 0.53, Fs from just over 50Hz to some 39Hz..
Did anyone do it? How likelly to damage a driver is it? (if I damage one, all 4 will be lost - they are no longer available!)
Thanks for your comments.
Lowering suspension stiffness lowers Qe, with the additional benefit of lower Fs.
But surgery sounds risky.
How about stuffing? I just happened to re-read the stuffing section in Dickason's LDCB 4th edition, and in some stuffing combos Qts was lowered from 1.1 to .7.
