non parallel h-frames
Old 10th November 2005, 07:06 PM   #1
smak is offline smak  Canada
Default non parallel h-frames
i was thinking about constructing some non parallel h-frames for my ciare 250 and pyle ppa-15's.
due to space restrictions though i had been putting the project aside but now am reconsidering the project, with a twist.
how might mounting the sub-woofers at 45 degree angles affect the sound?
i've attached a rough image of the concept.
using this method i hope to gain some leeway on how much room is necessary behind the speaker.. i'm not sure if the theory equates though since soundwaves dont emit straight back from the magnet of the drive only.. in this case the soundwaves emited from the rim of the cone would reflect off the rear wall first instead.
Old 11th November 2005, 07:22 AM   #2
Rudolf is offline Rudolf  Germany
Rudolf's Avatar
Soundwaves donīt emit straight from the magnet, indeed. Since a loudspeaker radiates sound in a radial fashion, you win no leeway behind the speakers by tilting them.
What you should consider: The H frame resonance gets somewhat smeared by arranging the woofers as described. And you will get some ripples in the frequency responce due to reflections from the adjacent basket.
Hope the diagram explains what I mean. Measurement is in the nearfield just in front of the H frame.
www.dipolplus.de
Old 11th November 2005, 07:45 AM   #3
okay that makes sense.. oh well was worth a shot.
back to the drawing board.
thnx
non parallel h-framesHide this!Advertise here!
W and other frames vs. driver's Qts hakunin Subwoofers 0 4th June 2008 07:41 PM
Help with OpAmps frames & Sound Changes irgendjemand Solid State 28 15th April 2008 01:43 PM
How does linkwitz count baffle width for h-frames and u-frames thadman Multi-Way 4 16th July 2007 01:40 AM
ESL Frames? ak_47_boy Planars & Exotics 17 17th January 2007 09:33 AM
Copyright ©1999-2017 diyAudio
