Hello Everyone,
I am David from the US...................... I enjoy perusing through these web sites and learning more about applications for the xt25. I have just ordered a pair of the 830875's to pair up with the xt's in a two way. This will be my first go at it without a premade and tested combo. My interest lies in learning the most from my new SoundEasy software and hardware as well as starting to develop my crossover design and measurement skills. I am looking for a little educated guidance here. I assume it would be best to get the actual T/S measurements from MY drivers then build the enclosures followed by re-testing the T/S measurements when the drivers are mounted in the actual enclosures. Then arrive at a starting point for xo development. Am I thinking clearly here.....................or is my newbie mind missing something. Any suggestions? Here are the specs if you like: http://www.tymphany.com/peerless/data/830875.htm http://www.tymphany.com/vifa/data/xt25tg30-04e.htm Cheers, David |
#2 |
Test the drivers on an Infinite baffle(a 4 x 8 sheet of MDF will work good) and then build the box of those parameters. Test the frequency response and whatever else you need for a crossover design in a final box.
| Guide Me PCB Connectors | haseeb | Parts | 1 | 10th June 2008 08:49 PM |
| New guide from TI | FastEddy | Parts | 0 | 19th August 2007 08:36 PM |
| Leach Amp Guide | wigginjs | Solid State | 2 | 27th August 2004 09:29 PM |
| DIY Loudspeakers Guide | giambi77 | Multi-Way | 0 | 30th December 2003 01:47 AM |
| Page generated in 0.07253 seconds (68.37% PHP - 31.63% MySQL) with 10 queries |
