Old 3rd March 2013, 01:11 AM   #21
Originally Posted by picowallspeaker View Post
Ohm's law can't be defeated
This is basically off-topic as it doesn't relate to a practical solution to changing an 8 Ohm driver to 4 Ohm.
But you CAN connect an 8 ohm driver to an amp that has -4 Ohm source impedance and thus the amp and driver will behave as if the driver was 4 Ohm.
If I remember correctly, an amp can have negative source impedance by virtue of positive feedback.
ACE BASS, which I don't understand, makes use of an amp with negative source impedance.
Don't ask me to explain in detail how all of this works.
For what it's worth,
Pete
Old 3rd March 2013, 02:03 AM   #22
AllenB is offline AllenB  Australia
Both of these options will work but they require skill, particularly using a positive feedback amp. I doubt I'd choose to use this method for this kind of problem myself let alone recommend it to someone that may never have heard of it.
The facts of the matter at hand are that the amp won't be damaged and the power difference is not that significant. Due to the way we hear things the power needs to be viewed in a logarithmic way. 20W is not much differrent to 10W. Just try it and see.
If you need more power then the most practical solution will be another amp or speaker.
Need a change Vivek Multi-Way 2 25th April 2008 06:41 PM
Change nafanja Swap Meet 2 14th April 2008 09:40 AM
change color of speaker cone?, how gychang Multi-Way 9 10th November 2006 08:26 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2013 DragonByte Technologies Ltd. (Resources saved on this page: MySQL 30.00%)
Copyright ©1999-2013 diyAudio
