My head is tangled from too many posts.
If I increase speaker efficiency by 3db, I actually double the output. but don't I need 10 times the output to double the apparent volume? er......... how many db would I need to increase by to double the apparent volume? I percieve that I have lost the (simple) plot. |
#2 |
Speakerholic
Best I can describe it is:
double the power input = 3dB increase 10X the power input = twice the apparent volume or 10dB increase dB is logrithemic so every 10 dB increase is twice the volume. ie: 100 is twice as loud as 90, 90 is twice as loud as 80 etcetera. Cal |
#3 |
The ear is not linear, so it takes an average of 10 db to percieve a 2:1 difference. An increase of 3db is a doubling in power, but it is only an increase in amplitude of .414. For a doubling of amplitude, it takes an increase of 6db.
#4 | |||
I already knew that the ear was logrithmic
#5 |
The formula for the power in watts is :
x dB = 10 log y x = number of dB increase y = times the power you get Look at what the guy said, he said an increase of .414 maybe he should have said power of 1.414 times versus the original power imput. You want it to use two times more power. 10 log 2 = 3.0102999566398119521373889472449 dB increase The formula for the amplitude in voltage is : z dB = 20 log w z = number of dB increase w = times the voltage amplitude you get You want it to use twice the amplitude. 20 log 2 = 6.0205999132796239042747778944899 dB increase. Understand a bit better now? Keep the questions coming!
DIYaudio for President ! |
#6 |
So for fun, since alot of people agree that 10 dB is twice as loud, you could invent a formula...
u dB = 33.219280948873623478703194294948 log v u = number of dB increase v = times the loudness you get Want it twice as loud so : 33.219280948873623478703194294948 log 2 = 10.000000000000000000000000000014 dB increase Wonderful, isn't it?
#7 |
So anyway, working in 3 sig fig if we can;
Again, I get the power equation: 10 X the Log of 2/1 and the Voltage equation.; 20 x the log of the ratio 2/1 - which works for SPL I also get the 10db required for the perception of double volume. ( said 10 times. I was wrong). I still don't see 1.414 ( I already tried it). I can see that; 33.2 log 2 = 10db is derived from the voltage/SPL equation, but i can't see what use it is. (un herring rouge?) How much do I need to raise the speaker power by to increase the SPL by 10db? Or is it as simple as saying that to increase SPL by 10db I must raise the power by 10db? So If I needed to raise the power by 10db; 20 log 3.2 = 10db ? |
#8 |
The guy was talking about voltage amplitude... he wanted to tell you what 3 dB of increase would do to the voltage amplitude.
If we take that formula... 20 log 1.414 = 3 dB Now, to get 10 dB more SPL, you need to increase the power by 10 dB, yes it's as simple as that. 10 dB = 10 log y y = 10^(10/10) = 10^1 = 10 That means to get 10 dB more SPL, you need 10 times the power. If with 1W you get 85 dB, to get 95 dB you'll need 10W, and to get 105 dB you'll need 100W, and to get 115 dB you'll need 1000W and etc...
#9 | |
Yes, you need to increase the voltage by a factor of 3.2 and the current by the same factor... why? Because power is equal to current x voltage so 3.2 x 3.2 = 10.24. More simple to use the power equation directly and forget about the voltage amplitude equation. You'll probably not need it.
#10 |
Life is simple.
So, more efficient speakers costs less than bigger amplifiers (bank for bucks). I'm my case, its a matter of jumping from 800W to 8000W, or find drivers that are 10db more efficient. So, ok, neither is going to happen but given my cheap chinese drivers, Eminence at 98db is a worthwhile swap. Life is simple |
| Simple 12v gain stage | dublin78 | Solid State | 10 | 14th April 2008 03:37 PM |
| Simple discrete unity gain buffer | tcpip | Solid State | 111 | 7th June 2007 05:55 PM |
| Simple gain question | maxw | Chip Amps | 8 | 12th May 2006 11:05 PM |
| simple BJT gain stage | hihopes | Solid State | 2 | 22nd September 2005 08:19 AM |
| room gain loudness | pxr5 | Multi-Way | 7 | 13th September 2004 04:50 AM |
| Page generated in 0.11521 seconds (78.66% PHP - 21.34% MySQL) with 10 queries |
