Old 5th November 2005, 02:24 AM   #1
smak is offline smak  Canada
Default glue for extra magnets
what type of glue have you all had success with using to hold extra magnets to your drivers?
my ciare 250 will soon have the +M mod and i figured i'd ask around in case it didnt seem stable enough just using the magnetic attraction alone.
Old 5th November 2005, 04:05 AM   #2
sdclc126's Avatar
JB Weld!
Soft Dome
Old 5th November 2005, 11:31 AM   #3
What is that/does it do?
Wkr Johan
Old 5th November 2005, 12:49 PM   #4
Ciare 250
hopefully will extend the highs and wean me off the supertweeter i added.
the extra magnet also lowers Qts to about 1.0 and should raise efficiency slightly
Old 5th November 2005, 10:22 PM   #5
Emiel is offline Emiel  Europe
Default Re: glue for extra magnets
Loctite 326 (http://tds.loctite.com/tds5/docs/326-EN.PDF)
This adhesive is specially made for bonding ferrites and steel.
Kind regards,
Emiel
Old 5th November 2005, 10:54 PM   #6
polkymon's Avatar
Strongest and best adhesive I've ever used.
I haven't found anything that this adhesive won't work with and it costs less than $3.
http://www.stickwithpl.com/products/...PLProductID=14
Ceramic Magnets Marik Swap Meet 5 16th September 2010 06:23 PM
Magnets, Magnets,Magnets! skooter Car Audio 10 25th September 2008 08:30 PM
Where to buy magnets Tenson Multi-Way 1 16th May 2007 12:47 AM
why use fixed magnets? killerfishes Multi-Way 16 27th May 2005 05:20 PM
Page generated in 0.09087 seconds (77.21% PHP - 22.79% MySQL) with 10 queries
