I bought a nice set of binding posts. I'm used to the cheap kind which have two or three parts. Well, this set has 7 per binding post. Can someone describe to me how these are designed to go together? And the picture doesn't show that part of the shaft, toward the left, is flattened, I think to "key" it. I'm so ashamed... Dave
I have a small website for my projects. |
#2 |
hi
id assume it would go binding post inserted from outside the cabint>black round thing (with taper towards outside of cabinet)>cabinet wall> flat washer >spiky washer> first nut up tight> then second nut to lock the first one on and stop it coming undone. not sure why theres 2 black round thing tho . . . . good luck, matto. |
#3 |
Yeah, it's the 2nd round black thingy that has me bumfuzzled. Perhaps it's just a spare part.
Thanks for the suggestion. Dave
#4 |
The second black thing is for metal chassis to isolate the posts/nut from the chassis.
www.audiosector.com “Do something really well. See how much time it takes. It might be a product, a work of art, who knows? Then give it away cheaply, just because you feel that it should not cost so much, even if it took a lot of time and expensive materials to make it.” - JC |
#5 |
The second black plastic part is used when the binding posts are installed through a metal sheet. The two plastic parts keep the metal body from touching the mounting metal plate.
#6 |
Peter,
Sorry, did not mean to repeat what you said. I guess we were both writing the answer at the same time. |
#7 | |
o yes, i forgot you need binding posts on amps too hehehe |
#8 | |
Well that would go on the inside of the cabinet, otherwise no isolation? Take |
#9 |
Right-o. Got it. I use wood for my chassis, so I didn't actually need isolation; hence, no need for the plastic thingy.
But now I know! Thanks all. Dave
| rca binding post adapter | vario | Multi-Way | 1 | 11th March 2008 05:02 PM |
| SpeakON vs five way binding post | ashok | Parts | 1 | 3rd March 2006 03:23 PM |
| binding post | yuval | Chip Amps | 1 | 19th May 2004 02:40 PM |
| Binding post suggestions | r0cket- | Parts | 2 | 28th August 2003 02:16 PM |
| Page generated in 0.09757 seconds (77.69% PHP - 22.31% MySQL) with 11 queries |
