Old 4th November 2005, 04:53 PM   #1
amirmk is offline amirmk  Israel
Default Low Power Handling Rating
I'm looking at Usher's 9930-20 tweeter and it has a rather low power handling rating, 10W normal and a 15W Peak. My amplifier can deliver about 60 watts, would this be a problem? The system is not bi-amped but I'm thinking about it for the future, then i'll use SE 2A3 for the tweeter.
Also about Bi-Amping, when removing the crossover from the speaker, I should leave in the resistance and baffle step compensation, right?
Thanks.
Old 5th November 2005, 11:34 AM   #2
As long as you use it wisely there is no such thing as an amp that is to powerfull, since you can use it as headroom.
If you're not bi-amping yet, you also have to take the mid/bass into account.
Wkr Johan
Old 5th November 2005, 11:58 AM   #3
The mid-bass is rated for over 100W, so it's not a problem.
What do you mean by saying headroom?
Old 6th November 2005, 02:13 AM   #4
Headroom generally means that you aren't operating near the limits. In this context, it would mean that you have extra power so that you don't clip, and can use the extra power for clean transients.
Old 6th November 2005, 02:30 AM   #5
David Gatti's Avatar
Default Re: Low Power Handling Rating
Thanks.
Usher is just being honest. Most tweeters would have similar thermal power handling. Actual power handling in a system depends on crossover frequency and slope, so at say 4 kHz & 12dB/octave, that tweeter woould be fine in a 200Watt system.
Old 6th November 2005, 03:01 AM   #6
Send a message via AIM to sr20dem0n
Exactly, an amp will only deliver as much power as you ask it to (through use of the volume knob). You could power that tweeter with a 2000 watt amp if you wanted to, unless you really cranked up the volume the tweeter would never see more than a few watts anyway.
power handling lsutherlin Multi-Way 1 19th October 2007 10:57 PM
Power output vs speaker power handling Bob0513 Chip Amps 4 5th November 2006 10:41 AM
Crossover/Power Handling Mutley666 Multi-Way 0 9th March 2005 09:55 AM
TL Power handling fortyquid Multi-Way 9 13th October 2003 12:18 AM
Power Handling Myren Multi-Way 1 30th October 2001 07:18 AM
Page generated in 0.09701 seconds (77.39% PHP - 22.61% MySQL) with 10 queries
