I need a set of tweeters with a few constraints:
They need to be under 30 dollars per tweeter. They need to be 4 ohm. They need to be able to handle at least 65 watts rms. They need to be able to be crossed over at 3500 hz. I have ben unable to figure out from lloking at specs on tweeters, where they should be crossed over, so right now I am playing a guessing game, so any input would be appreciated. |
#2 |
Speakerholic
The only thing I understand is the 30 dollar limit.
Why don't you tell us what you are doing so we can assist a little more. Your post makes it difficult to help. |
#3 |
check Zaph's tweeter mismash.
#4 | |
Well, i had a nother post located here: components questions However, no one responded to it. That explaind what I am trying to do. I under stand it is not the best way or even a good way to set up some components. I just want to know if it would work at all. |
#5 |
Wiring 2 4-ohm loads in series will get you an 8 ohm load, not 2.
#6 |
Speakerholic
If you want a tweeter that you can cross over at 3500hz, go to PE or other supplier and get a tweeter that has an Fs of 1750Hz or lower. It doesn't need to be 4 ohm. Try this link. Partway down, the domes start. Pick out some and come back with your ideas.
http://www.partsexpress.com/webpage....46098&desc=ASC |
#7 | ||
MG27TG29-04 DX25TG05-04ohm |
#8 |
mg is the way to go forget the other
for image and overall sound |
#9 |
If you want to cross over at 3500, look no further than the Seas 22TAFG. The tall order harmonic distortion above 3kHz is the best I have ever tested. The second best would be the Accuton C23, but that costs in the $200+ range.
Crossing tweeters over that high is relatively uncommon however. Your midrange had better be very small, and mounted very close to the tweeter. Seas 22TAFG Frequency Response Seas 22TAFG Harmonic Distortion Seas 22TAFG Cumulative Spectrum Decay
-Zaph|Audio- |
#10 | |
What do you mean by very small? I was planning on using a 6.5" Boston Acoustic rally series midwoofer. the specs on it from the company are: Recommended Amplifier Power: 20-275 watts Frequency response: 60-20KHz (+/-3dB in car) Nominal Impedance: 4 ohms Sensitivity: 90dB (1 watt / 1 meter) The mid and tweeter would bve mounted about 2 inches away from each other. |
| Why not a ribbon tweeter instead of a horn tweeter? | Curly Woods | Full Range | 9 | 15th July 2009 04:09 PM |
| Tweeter help for Miller & Kreisell Tweeter 17500 | merajsalek | Multi-Way | 4 | 3rd September 2008 03:41 AM |
| Linaeum Dipole Tweeter as a Super tweeter? | ktuuri | Planars & Exotics | 5 | 17th June 2008 06:52 PM |
| Round radiating tweeter, aka "Enterprise 1" tweeter! | tubee | Multi-Way | 39 | 13th May 2007 09:03 AM |
| Titanium tweeter vs Ribbon tweeter | goldyrathore | Multi-Way | 14 | 17th May 2004 07:21 PM |
