Old 3rd November 2005, 06:43 PM   #1
Question dual voice coil impedance switching
Say that you had a dual voice coil driver and you wanted to provide an impedance switch to get 4 or 8 ohms.
What are the effects of:
Shorting out one coil?
Opening up one coil?
Seems that shorting out would cause some kind of magnetic feedback to the other coil.
what about mechanical or electrical specs?
Old 3rd November 2005, 06:44 PM   #2
oops - one diagram missing - dual 4 ohm with dual pole switch to leave an open coil. You get the idea.
Old 3rd November 2005, 09:32 PM   #3
simon5 is offline simon5  Canada
Shorting or opening up the coil will change the Qts. You could use a potentiometer to play with Qts.
DIYaudio for President !
Old 4th November 2005, 11:08 AM   #4
megajocke's Avatar
Leaving one coil unconnected causes Qes to double. Shorting one coil will give you the same Q as series or parallell, it's just that sensitivity will be lower. (The shorted coil will give the same damping as when driven by a voltage source).
If you want to make a subwoofer with an impedance switch or something like that you should use a double pole changeover switch so you can choose between series and parallell.
Old 4th November 2005, 10:24 PM   #5
Thanks.
I wondering if it's possible to do 4 or 8ohms with a switch.
Doesn't look like it. Or I can, but it's not optimal.
Old 7th November 2005, 07:05 PM   #6
How do these darn switches work?
http://www.kustom.com/products/pa/sw..._impedance.asp
http://news.harmony-central.com/News...ccuSwitch.html
Both say 4 or 8 ohms?
Not 4 or 16 ohms.
Old 7th November 2005, 07:11 PM   #7
Well 8 and 16 for the Kustom
Not 8 and 32 like I'd expect.
Dual Voice Coil or Single - Sub kdhorne73 Car Audio 21 19th February 2009 08:35 AM
Dual Voice Coil Parameter Adjustments BlueWizard Multi-Way 10 10th August 2008 06:49 PM
dual voice coil woofers el`Ol Multi-Way 0 21st January 2006 09:22 AM
Dual voice coil for feedforward? Mr Evil Multi-Way 0 17th April 2005 03:02 PM
Dual voice coil wiring question bigshooter13 Multi-Way 18 4th October 2003 09:18 AM
Page generated in 0.09725 seconds (72.56% PHP - 27.44% MySQL) with 11 queries
