I can't find 13/12 Gauge air core inductors for the proac response 2.5 clone.
Any substitute ? |
#2 |
http://www.partsexpress.com/webpage....ID=197#16gauge
Jantzen Cross-Coil Copper Foil Inductors The Jantzen Cross-Coils are premium-quality, audiophile-grade copper foil inductors. They feature 99.99% pure copper foil windings separated by an extremely thin layer of polypropylene film and tightly wrapped around a hardwood core, resulting in very low magnetoshrinkage factor and virtually zero FM distortion. The foil approach outperforms conventional round-wire inductors by providing over 12 times the surface area through which high-frequency electrons can travel, minimizing skin-effect problems and providing consistently low power-distortion figures. Very close to the "ideal inductor" in all respects, every coil goes through a specially developed Jantzen anti-oxidizing treatment and measurement procedure prior to packaging. Tolerance, +/-3.0%; power handling: 350 watts RMS for 16 gauge, 500 watts RMS for 14 gauge and 650 watts RMS for 12 gauge. |
#3 |
solen.ca also carries 10 and 12 gauge inductors. so does northcreekmusic.com.
| What's the best wire gauge to run to the HU? | phrarod | Car Audio | 14 | 14th June 2008 12:35 AM |
| which gauge wire for PSU???? | cbutterworth | Tubes / Valves | 6 | 13th December 2006 12:52 PM |
| PPI A404 + JL 500/1 - on same 4 gauge? | frankj | Car Audio | 3 | 1st August 2005 05:42 AM |
| Conversion of Gauge in mm | cristiano | Multi-Way | 21 | 30th June 2005 03:55 PM |
| fet wire gauge | MikeZ | Pass Labs | 2 | 21st April 2004 12:43 PM |
| Page generated in 0.07695 seconds (62.43% PHP - 37.57% MySQL) with 10 queries |
