Group Delay Question
Old 1st November 2005, 12:37 AM   #1
69stingray is offline 69stingray  United States
Send a message via AIM to 69stingray Send a message via MSN to 69stingray Send a message via Yahoo to 69stingray
Default Group Delay Question
I don't think I understand group delay. Can someone give my the "Group Delay for Dummies" version of what it means and how it effects loudspeakers?
For example, I have attached the group delay plot from WinISD for the same driver (Dayton 7" Aluminum Cone) with 5 different volumes (the 5 different alignments available in WinISD).
What should I learn from the group delay of each alignment?
Old 1st November 2005, 12:48 AM   #2
soongsc is online now soongsc  Taiwan
soongsc's Avatar
The definition of group delay is -dphase /dfrequency. Are the larger peaks the higher volume setting?
Hear the real thing!
Old 1st November 2005, 01:04 AM   #3
Sjef is offline Sjef  Netherlands
Group delay is nothing more than the phase characteristic corrected to frequency.
In simple words, When a loudspeaker has a group delay of 2mS at 200 Hz and a group delay of 20 mS at 40 Hz (not uncommon for reflex enclosures) this means that when two tones of 40 and 200 Hz are played at the same time the 40HZ tone whil come out 20-2=18mS later than the 200Hz tone. in other words, the low frequencies are walking behind the low-mid frequencies in this example.
hope this helps.
Old 1st November 2005, 01:22 AM   #4
Thanks Sjar-
In that case, using the sample of the graph I posted. Looking from 40 Hz on up, the Light Cyan curve (the real peaky one) would be "better" from a group delay standpoint?
How audioable is group delay? Is there a time lapse that starts becoming objectionable? For example, will the group delay difference at 40Hz be noticeable between the light cyan curve and the red curve?
Old 1st November 2005, 01:28 AM   #5
ShinOBIWAN is offline ShinOBIWAN  United Kingdom
ShinOBIWAN's Avatar
Keep the group delay(GD) below 10ms in the 30-40hz+ range if possible.
Be aware that ported designs generally have worse GD than sealed at lower frequencies because of the 180degree phase shift at the tuning frequency.
Group delay is really only problem for the lowest frequencies, which one of the reasons why I much prefer sealed with a LT.
Old 1st November 2005, 01:31 AM   #6
I'm sorry, somehow I don't see your attacement.
There ar lot's of discussions of how audible the group delay is, but it's controversial. Every loudspeaker suffers from group delay. When you really want the least group delay just build the biggest enclosure you can and this problem is solved. But that means you won't get any bass from your system anymore. So it's all about compromise. The only choose the least worst alligment
Old 1st November 2005, 01:35 AM   #7
carlosfm is offline carlosfm  Portugal
Banned
Group delay is a problem over the entire spectrum, crossovers also have group delay.
The higher the slope the worse it gets, and also the crossover type.
For instance, 2nd order Bessel has much less group delay than 2nd order Butterworth.
It is clearly audible in the midband and treble.
Old 1st November 2005, 01:40 AM   #8
ShinOBIWAN's Avatar
For instance, 2nd order Bessel has much less group delay than Butterworth.
Do what I do and use FIR filters
Seriously though, you've got to really mess up your design to get anything like 10ms in the mids. According to SW I've got 2ms as a worst case from 100hz-20Khz
Old 1st November 2005, 01:40 AM   #9
Thanks everyone for your replies, very interesting.
Old 1st November 2005, 01:50 AM   #10
Banned
Try it, listen and compare.
It's audible, the mid/treble gets slower and less detailed.
It's even audible in active filters, simpler is (sounds) better.
Software doesn't make the whole speaker, some decisions are made later, depending on the priorities.
Group Delay QuestionHide this!Advertise here!
Acceptable group delay mitchyz250f Multi-Way 43 28th November 2008 08:40 PM
Question about the group delay of this: BAM Multi-Way 1 23rd November 2003 06:07 PM
Group Delay............When Is Too Much Too Much? OMNIFEX Multi-Way 0 14th March 2003 08:30 AM
group delay question. theChris Multi-Way 8 28th November 2002 12:35 PM
Group Delay? Ignite Multi-Way 6 13th November 2001 06:52 AM
