Old 31st October 2005, 07:05 AM   #1
Default rubbing voice coil - repairable?
I have been gifted a damaged 15" Wharfdale D-054A woofer that came from a pro subwoofer.
The there's a rubbing noise when moving the cone so it appears the voice coil is toast.
Google searches haven't turned up any info.
The woofer is pretty unexceptional looking. Cloth surround, textured paper cone, thin stamped steel basket. Magnet is not very big. Approximately 1.25" by 6".
Fixable or paper weight?
Old 31st October 2005, 11:48 AM   #2
Hi, I've read that some older, large drivers are susceptible to sagging, although I don't know where it occurs. You can try running it in an inverted(180 degrees) position, if you can distinguish which side was formerly up.
Old 31st October 2005, 03:38 PM   #3
This was a vertically mounted woofer. It's only a couple years old at most.
Old 31st October 2005, 05:13 PM   #4
dnsey is offline dnsey  United Kingdom
Does the voicecoil show continuity? Is it shorting to the frame when the cone is moved?
If yes to the former and no to the latter, it's probably worth trying to recentre it.
Carefully remove the spider and cone surrounds from the chassis, shim the coil, and refix. Easy! (Actually not difficult, but care and time required).
Old 31st October 2005, 05:45 PM   #5
Interesting. I didn't bother testing it with a DMM.
Based on the description, he was underpowering it and running the amp into clipping.
I'll check that out tonight.
How to remove cloth surround? I've seen descriptions for rubber and foam but not cloth.
There's a multipart gasket on the rim that I guess I just carefully peel off. Could someone recommend a solvent to help remove the surround from the basket?
Old 31st October 2005, 06:38 PM   #6
pinkmouse's Avatar
It's worth trying with just a hot air gun firstly, before you get into solvents. Old glue usually softens quite well with judicious heating.
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 1st November 2005, 05:54 PM   #7
Vertically = up & down.....so what I'm trying to convey is, if you were to look at a wall clock, rotated from the "12" position, 'til it is at the "6". = 180 degrees(not Fahrenheit or Celsius).
I could mess up a 1 car funeral.
Old 1st November 2005, 06:01 PM   #8
I see what you're saying now. I didn't read your post carefully enough.
However, I did try to reposition the voice coil and see if I could eliminate the rubbing but could not.
I'll get out the heat gun tonight and see if I can get the surround off.
Is there any hope for a driver with a rubbing 39mm voice coil? kappa546 Multi-Way 10 7th May 2009 09:38 PM
voice coil rubbing? Dr.H Multi-Way 2 29th January 2009 01:57 PM
Coral Beta rubbing voice coil / cloth surrounds RemcoB Full Range 6 21st April 2008 09:29 PM
Single Voice Coil Vs Double Voice Coil Subwoofer Workhorse Car Audio 6 12th April 2007 06:36 AM
an amp for each voice coil? speekergeek Multi-Way 1 12th December 2003 02:31 AM
Page generated in 0.09732 seconds (75.88% PHP - 24.12% MySQL) with 10 queries
