Old 31st October 2005, 01:09 AM   #1
xyrium is offline xyrium  United States
Default It's done!
So, I finished my replica of the Zaph L15/27TDFC (his uses the TFFC) speaker. I used the PE 0.38 cu ft cabinet, but sanded the finish off of the front so I could apply a flat black finish. Now I await the 8-32 screws from PE, because I forgot to order them, so this image uses 1" drywall screws.
Anyway, they sound very good, even though I haven't glued the baffle on yet. One bad idea of mine was to use Goop to mount the xover board. Now, I won't be able to remove it if something stops working at one point...
Also, any opinions about using Goop over hot glue for the xover components? Will the chemicals in Goop eat away at the components (inductors, etc.)?
Anyway, thanks to John Krutke for putting this design together! I've been waiting to find a tight and tuneful 5" system, and this is it!
Paul Hanley
Old 31st October 2005, 03:45 AM   #2
Me Kong is offline Me Kong  Canada
Hi Paul,
I am building this spaeker and I having problem to find the .05 MH inductor with .05 Ohm resistence.
Can you tell me where you buy it for your build?
Also did you change tweter padding to reduce out put of TDFC ?
Thank you for information.
Me Kong
Old 31st October 2005, 10:45 AM   #3
Hello Me Kong,
I bought the inductor from Parts Express. The part number is: 266-798. The DCR on it is 0.07. A negligible difference IMO.
Yes, I changed the tweeter padding slightly. I only used a 1.5 Ohm resistor. However, again, it's probably a negligile if even audible difference.
Good luck, it's a great design.
Paul
PS: Why isn't my pic showing up? Hmmmm.
Originally posted by Me Kong
Hi Paul,
Me Kong
Old 31st October 2005, 01:13 PM   #4
One more try to post this file. Something weird is going on here.
Old 31st October 2005, 06:23 PM   #5
Zaph is offline Zaph  United States
Zaph's Avatar
Glad to hear you like it.
I can't see the picture either, I just get some kind of strange error. If you want, you can mail it to me and I can host it for you.
John
-Zaph|Audio-
Old 31st October 2005, 06:31 PM   #6
pinkmouse's Avatar
We're having server issues - things should be back to normal tomorrow...
Al
I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort
Old 31st October 2005, 07:34 PM   #7
Pinkmouse, will I need to repost, or do you have the images?
Old 31st October 2005, 11:38 PM   #8
Hello John,
How criticle is the DCR of the .05mh inductor in this desing?
It is not so easy to find and I will un wind as you show in your site but I worry for DCR.
Me Kong
Old 1st November 2005, 12:08 AM   #9
Ok, try this:
http://pg.photos.yahoo.com/ph/xyrium/album?.dir=/cc01
Page generated in 0.10373 seconds (75.90% PHP - 24.10% MySQL) with 9 queries
