hey everyone, i was looking at these
http://vikash.info/audio/W3-871S/ and i was wondering what kind of danish oil was used? i have birch plywood and i bought the golden oak danish oil and it looks very bland. what kind should i try? thanks alot! -dave |
#2 |
anyone?
#3 |
*crickets*
#4 |
Dave, Chill. Things take time!
As far as I know, Vikash just used plain, uncoloured Danish oil. However,all wood takes finish differently, you may just need more coats. Don't give up yet!
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#5 |
diyAudio Moderator Emeritus
"The human mind is so constituted that it colours with its own previous conceptions any new notion that presents itself for acceptance." - J. Wilhelm. (But I still think mine sounds better than yours.) |
#6 |
did you polyurethane over it?
#7 |
Dave, how long did you spend sanding them? That makes all the difference.
#8 |
...truth seeker...
With most finish you apply to wood, more coats are better. Along with this, a progresssion to finer grades of abrasive will allow the beauty of wood to come through.
Successive coats "build" the finish. With polyurethane this is easier to witness than oils. Still, oils have some gap-filling solids and the surface appearance will change with additional coats. The abrasives can include steel wool (look for XXXX) and wet-dry papers typically used in auto body finishes. Each step in the re-sanding process should be thorough. Trying to remove marks with 320 grit that should have been wiped with 120 is not the best way to spend your time. You are only limited by your interest in seeing what can happen with the next step. You can find products similar to Vikash's danish oil made by Watco and Deft edit: addition of product suggestion
...call me Ed...Special Ed... EnABL kit http://www.diyaudio.com/forums/swap-meet/119852-enabl-kit.html DCB1 parts http://www.diyaudio.com/forums/swap-...ml#post2361098 |
#9 | |
The shop owner that sold me the danish oil said it works well with some woods, with others not so well. On my little PC speakers, veneered with Bubinga, it was relatively easy to get a shiny and nice finish with the oil. (although Iīm not a good "sander") My tall TLīs in birch-plywood still donīt look as I want them to. I sanded them again and again but still one of them looks "bland". Take your time with sanding and try to get it real smooth (coarse to fine grits), then properly clean the dirt from sanding before you apply your oil. Usually youīll see already with the first coat if itīs gonna look nice or not. But yeah, two layers is what Iīd recommend. greets & good luck Jens
jens |
#10 |
No polyurethane. Just three coats applied six hours apart. Adding more for a deeper lustre finish. It's the ply ends which change colour the most.
| something to finish mdf | paulfk | Multi-Way | 14 | 14th March 2009 02:04 PM |
| Does anybody know how to get this finish? | wrl | Multi-Way | 177 | 30th January 2008 09:15 AM |
| Help! Finish gone bad | ShinOBIWAN | Multi-Way | 13 | 7th July 2006 10:54 AM |
| FAO: Vikash | ShinOBIWAN | The Lounge | 11 | 24th October 2005 09:13 PM |
| MDF Finish | bjackson | Multi-Way | 26 | 3rd June 2005 11:41 PM |
| Page generated in 0.11646 seconds (78.12% PHP - 21.88% MySQL) with 10 queries |
