I've been building speakers on and off now for almost 15 years. For me it's been the same formula of MDF, clamps and glue. I have a couple TB W3-871's in boxes looking for a home, but I'm looking for something different than the traditional boring MDF box.
I've searched the forum and found a thread on spherical enclosures which is kind of neat, but that's about it. Has anyone done anything with unconventional enclosures and been happy with the results? |
#2 |
Double wall Stainless steel 316? with 2" tangband (actually a small stainless steel coffee cup)
6 mm massive aluminium? with 3"tangband (actually a small flower vase fo approx 1.9 liters) The double wall stainless steel are in pogress I've got some other more or less wild ideas wich I will put into practice like Terazzo stone balls etc.
better be indoubt untill you're sure |
#3 |
I used pvc pipes and had great results. ( See my thread below). It took a lot of adhesive and bondo but had fun doing it. I ended up with a solid and heavy cabinet. I thought of this method trying to figure out how to make curved sides.
Not sure how it would work on larger boxes, might be too cumbersome. |
#4 |
That's awesome. That's the kind of ideas i'm looking for. The PVC pipe idea is brilliant.
indoubt: How do you have the driver secured in the container? |
#5 |
Here is my PVC TL with an NSB. Line is about 1/2 to 2/3 stuffed with sacraficed pillow internals. Cat5e cable soldered to connectors. Baffle is cardboard. Legs now attached look like rocket fins.
http://photobucket.com/albums/b81/fp...t=P1010065.jpg |
#6 |
Polystyrene sheeting. Full-on Russ Andrews idea taken to its extremes. Odd, but it works. Something else that also works for things like horns or some types of TQWT: ordinary, decent quality pine.
#7 |
I have a small website for my projects. |
#8 |
Perhaps a bit close to boring MDF, but a while ago I was playing with laminated MDF, laminated with an acrylic rubber mastic. (Actually used as a roof sealer - it is water soluble and contains no solvents - but sets to a very nice lossy reasonably hard rubbery material.) I did some measurements of the resulting damping properties of the sheets and was really impressed. Some of the best were simply three sheets of 8mm MDF laminated with about a 0.5mm layer of the rubber material.
Easy to make, and very tempting as a box material. |
#9 | |
Offtopic: The cup's will be driven from an Class D (41Hz Amp3) amplifier and a M-Audio transit external soundcard from my laptop The amp is done (except the Volume knob) and is tested in my main system. It sounds very very good. The backplate with all connections is now also mounted Edit: the speakers in my avatar are also not made of MDF except for the bracing. They are multiple layers of curved birch plywood.
#10 | |
Is the 'stick' at the bottom actually a pipe?
"A squid eating dough in a polyethylene bag is fast and bulbous, got me?" |
| Questions regarding tone arm materials and designs | Zero One | Analogue Source | 9 | 11th June 2006 10:12 AM |
| Possible enclosure materials? | esl_retro | Multi-Way | 0 | 10th February 2005 07:41 AM |
| Enclosure materials. | rakeshln | Multi-Way | 0 | 10th June 2004 02:41 AM |
| lightweight enclosure materials | jbrom | Multi-Way | 30 | 11th March 2002 09:00 PM |
| Materials For Spherical Enclosure | Ignite | Multi-Way | 15 | 12th December 2001 08:15 AM |
| Page generated in 0.11625 seconds (84.00% PHP - 16.00% MySQL) with 10 queries |
