Old 24th October 2005, 02:24 PM   #1
polkymon's Avatar
Default Pvc pipes for curved walls
Tried using pvc pipe for curved enclosure. Glued 1" pipes around sides and filled them with sand. Covered the sides with screening and Bondo. Finished by painting faux cherry on top and sides.
Old 24th October 2005, 02:49 PM   #2
tade is offline tade  United States
Send a message via AIM to tade
I like it very much!
I am very cheap, so would likely end up cutting them in half. Of course then i could nto foll them with anything, and cutting them in half would probably be very difficult.
That is a dayton RS driver? How do they sound?
Super job!
Old 24th October 2005, 05:51 PM   #3
I went to the lumber store and found 3/8" thick flexible plywood,
really cool stuff.
Old 24th October 2005, 06:24 PM   #4
trusound's Avatar
Send a message via AIM to trusound
3/8 bendyboard is heaven...then when you use that in conjuntion with fiberglass, it's magic...
this was made from multiple layers of 3/8 bendy board and fiberglass
http://pg.photos.yahoo.com/ph/randy_...18.jpg&.src=ph
http://pg.photos.yahoo.com/ph/randy_...1e.jpg&.src=ph
Old 24th October 2005, 07:20 PM   #5
sdclc126's Avatar
Trusound -
That's a sweet looking design you have - looks a little like an orion, but with a sealed bass unit? Is that a 10" SEAS woofer there? And how did you build the bass enclosure? Looks like laminated mdf maybe? That would be one solid box, probably with great sonic characteristics given the triangular shape. How are you amplifying/crossing over this? Active, etc?
Thanks for info.
Soft Dome
Old 24th October 2005, 08:20 PM   #6
trusound's Avatar
Thanks!!!!
Yes it is modeled after the orion...but I took the looks to something that I would like and made it more organic.. all SEAs drivers T25CF002, W22EX, W26FX001.
The top will be painted a candy burgandy while the bottom that holds the 10 will be wrapped in a cherry veneer...
to make the bottom, I made a jig out of 3/4 mdf. and then traced it onto a sheet of 3/4 mdf and rough cut each one with a jig saw. Then I used the jig and a trace bit on a router table to make perfect copies..
http://pg.photos.yahoo.com/ph/randy_...51.jpg&.src=ph
http://pg.photos.yahoo.com/ph/randy_...b4.jpg&.src=ph
http://pg.photos.yahoo.com/ph/randy_...b2.jpg&.src=ph
http://pg.photos.yahoo.com/ph/randy_...f0.jpg&.src=ph
Old 24th October 2005, 08:40 PM   #7
eLarson is offline eLarson  United States
eLarson's Avatar
trusound -
Interesting design. Reminds me of a cobra coming up out of a basket.
Would a woodchuck bother to chuck MDF?
Old 24th October 2005, 08:50 PM   #8
sdclc126's Avatar
With the triangle shape of the bass cabinets, I think triangle-shaped baffles for the mid/tweet section would give them a cohesive look, but to each his own.
Trusound - have you done any listening measurements with the baffle, or were you just going primarily for the look? Some people just build without measuring, which is cool.
Soft Dome
Old 24th October 2005, 08:50 PM   #9
trusound's Avatar
I was just playing around with shapes..and that is what I came up with..for the most part it was to see if I can get the bendy board to do want I wanted to so for the most part is was a test set...
Old 24th October 2005, 08:55 PM   #10
trusound's Avatar
it's funny you said that, I originally made the top baffle in the shape of a triangle but didn't care for it to much which is why I changed it..
that was after I built the bottoms and I wasn't going to waste all that wood and time...later I would like to make another set that mimics the top shape and flows better...
And yes, I listend to it for a while and it sounds fantastic...needs a little eq'ng because the baffle is a little small, but I'll never go back to a boxed loudspeaker.. I plan on eventually mating these with a deqx
BR vent and walls...... jay1st Multi-Way 8 27th January 2008 08:40 PM
My sand filled curved side walls project in progress! sqlkev Multi-Way 17 11th August 2006 05:27 AM
making curved walls thin paulspencer Subwoofers 2 10th December 2004 06:59 AM
THOR with curved side walls? runer Multi-Way 1 3rd August 2004 01:30 PM
non-parallel walls sangram Multi-Way 14 7th April 2003 08:13 AM
Page generated in 0.11046 seconds (82.39% PHP - 17.61% MySQL) with 11 queries
