Does anyone have a completed crossover for these that I could borrow for a design of mine? I know RAW uses it in his designs but I assume those are proprietary and not open source. If this is not so, I'd be happy to have a look at them.
#2 |
Not only is the crossover proprietary but it is not for the G2Si but for an OEM model, the RA104.5.
Bob |
#3 |
Well on his website he indicates:
RA104.5 ribbon (Aurum Cantus) and the cost is 100 dollars, which is very much inline with a G2si. |
#4 |
As Bob said our ribbon is made by Aurum Cantus but is NOT the G2Si
Ours has a different motor as well as face plate.Our face plate I had made at 104.5mm for those who had previous tweeter hole cut out at 104.5mm this will fit with a small cut in the inside of the opening for the motor. Almost a drop in replacment for driver holes cut to 104.5mm. Nothing even close to the same between the G2Si and the RA104.5. Yes a great price in line with other ribbons And yes 6th order at 3500. Why 6th well stepper the slop the better dispersion off a ribbon and driver! AS well a more controled inductance and resistance and impedance with a step order nextwork. This is achieved by more parts but smaller valvues. Say in a 2nd order network you have to use a 1.8-2.2mh on a 6th order you use 2-3 inductors ranging from .1mh-.7mh Al |
| Ej Jordan JX92s and Aurum Cantus G2si with Griffin crossover | Chris74 | Swap Meet | 7 | 7th April 2009 10:19 PM |
| BIB's and WR125-16ohm | mrpopgun | Full Range | 0 | 10th November 2006 06:57 PM |
| Wr125 Mtm | dawaro | Multi-Way | 3 | 7th November 2006 10:31 PM |
| Wtb: Wr125 | bjackson | Swap Meet | 0 | 8th November 2005 03:50 PM |
| Any new WR125 projects out there? | Timn8ter | Full Range | 17 | 27th September 2005 02:45 AM |
| Page generated in 0.07390 seconds (71.34% PHP - 28.66% MySQL) with 10 queries |
