This is for Zaph's L15/27TBFC project. I've attached links to both his schematic, and my finalized xover. I tested it by running a frequency generator app on my laptop, and took the outputs to a receiver, and then an a/d/s woofer I have lying around. Although I can certainly hear that each section is performing eith a high or low end rolloff, I'm not sure it's doing it with the slope it was designed for, as I can still hear 200Hz (though extremely low) on the high pass section, and I can hear 6kHz on the low pass. I think John had them set up for about 18dB rolloff, so I'll get an SPL meter on it later.
I figured you'd rather me link to your site than copy and paste without permission John. His schematic: http://zaphaudio.com/audio-speaker12-xover.gif My xover: http://paulhanley.com/crossover_cnfm.jpg If anyone can give this a quick review, I would truly appreciate it. Thank you! Paul |
#2 |
Hi Paul,
Your layout seems ok.... Even with 18dB filters, some high or low frequencies will pass through the LP and HP sections. The value of your caps are right, but are you sure that your cools has the right value, and that you didn't switch them around by mistake
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com |
#3 |
Hello Jan,
Thanks for giving it a review, I needed the additional confirmation! I also confirmed that the coils are indeed the correct value. So, this means, into the cabinets they go, and the repainted baffles may go on tonight! I used PE premade cabs, but sanded the half-glossy finish off of the front and applied a flat black finish instead. I also cut out the center brace to remove any air restrictions/reflections in the cabinet. Very exciting! Regards, Paul |
#4 |
Please take a picture of your new speakers and post it here
#5 |
I most certainly will! Thanks again!
Regards, Paul |
| I Think I Understand Baffle Step...Plz Confirm | 69stingray | Multi-Way | 13 | 6th December 2006 05:33 AM |
| Please confirm my transformer math. | leadbelly | Tubes / Valves | 7 | 12th March 2005 12:52 AM |
| help needed to confirm part numbers | chipco3434 | Chip Amps | 6 | 15th August 2004 12:05 PM |
| Can somebody confirm this calculation? | Eton | Multi-Way | 2 | 12th December 2003 06:16 AM |
| Fred D... can you confirm this... | MWP | Digital Source | 3 | 24th May 2003 06:31 AM |
| Page generated in 0.07961 seconds (69.76% PHP - 30.24% MySQL) with 10 queries |
