Old 21st October 2005, 07:48 PM   #1
David Gatti's Avatar
Default Using a car-audio active crossover
Has anybody tried it for their home speakers/subwoofer?
Seems there are quite a few out there at low cost.
Is the quality good enough for home audio?
Old 21st October 2005, 08:04 PM   #2
I've used car audio active crossovers in any application,
car, test bench, home audio. If you use a good brand the
circuit design would be the same as any esoteric home product, ie
I was using Zapco which uses 55xx opamps. I also used
Nakamichi. The good ones have dual rail with switch mode
power supplies.
Old 22nd October 2005, 03:13 AM   #3
MTX makes one (car xover with a wall wart 12v supply) and sells them on eBay for $20-$40 usually. under The Stereo Direct.
Old 22nd October 2005, 08:35 AM   #4
My main concern is the switched power supplies they use.
Is this something I should be concerned about?
Old 22nd October 2005, 01:57 PM   #5
Volenti is offline Volenti  Australia
I've used 3 different brands of car audio x-overs in home audio at various times (Coustic, Phillips and Alpine) all had switching supplies, I had no issues with any of them.
Old 22nd October 2005, 05:30 PM   #6
Pallas is offline Pallas  Pakistan
I've used an AudioControl 24XS at home with a wall wart and no adverse effects, though I don't currently do so. (No need.)
However, like all home and car AudioControl gear I've used (admittedly, nothing made in the last 4-5 years) it does have a turn-on thump so I kept it powered on full-time.
Old 22nd October 2005, 06:09 PM   #7
I've used an AudioControl 2XS on a home subwoofer application before. It worked fine and dandy.
Old 22nd October 2005, 07:46 PM   #8
Thanks guys! I 've just ordered this :
Old 22nd October 2005, 08:00 PM   #9
trusound's Avatar
Send a message via AIM to trusound
I've used my alpine h900 to try out my open baffles that I'm building....worked great
Old 24th October 2005, 01:55 PM   #10
Jim85IROC's Avatar
Send a message via AIM to Jim85IROC
You may want to reconsider and perhaps order something that's at least of respectable quality. Pyramid products are the lowest common denominator in the car audio world, and considering how much junk is out there, that's really saying a lot.
Once upon a time I used an active Pyramid subwoofer crossover and it was the most worthless piece of junk I ever put into a car.
Audio Arts Active Crossover les winter Multi-Way 3 22nd June 2009 08:17 PM
Passive crossover into active crossover hahfran Multi-Way 16 10th February 2008 06:16 PM
LC Audio active crossover. Peter Daniel Solid State 12 22nd September 2006 12:58 PM
XVR1 active crossover, discrete active stage promitheus Pass Labs 18 22nd July 2002 01:29 AM
Page generated in 0.10601 seconds (76.54% PHP - 23.46% MySQL) with 11 queries
