Aurum Cantus or Raven?
Old 21st October 2005, 07:45 PM   #21
planet10 is offline planet10  Canada
frugal-phile(tm)
planet10's Avatar
Originally posted by one1speed
It seems the Heils are not that efficient. How do you deal with the difference of them being 4 ohms and only 93 db? I'd imagine the Corals are much more efficient.
We measured the Heils at over 100 dB (and the padding needed to match them to the push-push pair of 92 dB Fostex confirms that....
Old ones seem fine, but when you can buy a new pair for the same kinda price (AMT had some up on eBay for $300/pr)... it will be interesting to see what one1speed gets in reply.
dave
PS: excuse the Excel charts (Excel is just so clunky)
community sites t-linespeakers.org, frugal-horn.com, frugal-phile.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 21st October 2005, 07:46 PM   #22
frugal-phile(tm)
planet10's Avatar
and here are pics of the Heil/Fostex i was referring to.
Old 21st October 2005, 07:48 PM   #23
frugal-phile(tm)
planet10's Avatar
and an earlier set of 3-way (eminance mid, and original alnico AMT woof/PR)
Old 21st October 2005, 08:30 PM   #24
one1speed is offline one1speed  United States
Dave
Thanks for the picts. I did hear back from Heil and they are saying $300 plus shipping/taxes for a pair. Not bad. Expecially considering the quality everyone speaks of. My only issue is that if I go in that direction, I need to find a way to mount them on an open baffle. Any thoughts?
Layne
Old 21st October 2005, 08:58 PM   #25
frugal-phile(tm)
planet10's Avatar
A hole with a "shelf"?
dave
Old 21st October 2005, 09:22 PM   #26
i had thought of that as well. have to admit, i don't love the idea. it seems from most of the mountings i've seen, including your picts, the front of the tweeter box is sitting in line with the driver/baffle. this would actually put the ribbon portion of the tweeter behind the baffle, which i'm guessing is not a good thing. i had wanted to mount the tweeter below the full ranger. i could sit it on the bass box, but it still would sit back too far i'd think.
maybe a small shelf could be built above the full ranger? but then i'd want it to sit close to the full ranger. i'm not sure this can work for this. would be tough to get it to work i'd think...
Old 22nd October 2005, 12:15 AM   #27
BTW is offline BTW
One more question, if you don't mind. It seems the Heils are not that efficient. How do you deal with the difference of them being 4 ohms and only 93 db? I'd imagine the Corals are much more efficient.
Thanks!
The AMTs by itself is 100 dB so , the Corals are at 95 dB and I actually need to use an L pad on the AMTs as they are more efficient than the Corals.
Old 22nd October 2005, 03:40 AM   #28
frugal-phile(tm)
planet10's Avatar
However it is mounted. i think i'd try getting the central part of the ribbon flush with the baffle.
dave
Old 22nd October 2005, 12:06 PM   #29
ralphs99 is offline ralphs99  Australia
ralphs99's Avatar
You could also consider the Eton ER4 which is a similar technology to the Heils, I believe.
I'm always a bit wary of putting down my hard earned for something that doesn't come well documented. In that respect the AC G2Si has been thoroughly tested. Check out:
http://206.13.113.199/ncdiyaudio/mar...st_results.htm
I'm in the middle of a new design at the moment. As part of the project I am trying out an Eton ER4 and will also be evaluating an AC 2Gsi and Raven R2 when they finally arrive.
My inital impressions of the ER4 are mostly positive. Smooth & detailed. Low efficiency, hard to mount and a rising response that needs some EQ. I'm currently struggling with it's dipole nature and the effect that has on the power response. More work is needed here.
I can send some FR plots of the ER4 if you're keen.
Ralph
Old 22nd October 2005, 07:27 PM   #30
Illusus is offline Illusus  Canada
Illusus's Avatar
The Eton AMT's price is double of the Heil and looks considerably less impressive, if that means anything. The Eton's efficiency is pretty low at 88db, not really what Speed is looking for.There's also the Mundorf AMT but its price is even higher (~$400 for a 2340) and efficiency only marginally better at 90db for the lower priced models; 104db for the rest; HF extension is lacking when compared to most super tweeters.
I'd take the Heil over other AMTs due to it's proven, well documented and impressive performance. My view may be coloured by a few years of lusting after a pair, now that I know they're still available at a relatively low price I'll be buying a pair in the near future, I'm not bound by the mounting issue that Layne is...anyone want to trade for a hardly used pair of OEM G3's ?
Fighting the program since 1976.
Aurum Cantus or Raven?Hide this!Advertise here!
Aurum Cantus G1 tolits Multi-Way 0 10th August 2009 01:23 AM
Hp Aurum Cantus fiscal Multi-Way 14 25th March 2009 10:28 PM
Aurum Cantus mandoman Multi-Way 35 21st August 2007 02:21 AM
Which brands and models use RAVEN, Aurum Cantus or ER4 from Eton Adrie Multi-Way 4 30th April 2004 04:41 PM
