3 way loudspeaker Project!
Old 19th October 2005, 12:58 AM   #1
Guijs is offline Guijs  Brazil
Default 3 way loudspeaker Project!
Hello,
Me and a friend, are planning to build a 3 way loudspeaker using these drivers:
- Hiquphon tweeter
- SEAS Excel W18E001 midbass
- SEAS L26 10'' woofer
I know well the Hiquphon OWI and SEAS Excel W15CH001 woofer and I realy like them. What do you guys think about using a Fountek 3'' Ribbon, or the Aurun Cantus G2 tweeter?
I'm thinking of using a 2500hz cutoff between the midbass and tweeter, and a 200hz cutoff on the woofer. With the option of bi- amp for the subwoofer in the crossover.
Also thought about a vented enclosure for the midbass, and a sealed enclosure for the subwoofer, but what about a TL project?
Any comments, suggestions?
Old 19th October 2005, 04:40 AM   #2
mudakas is offline mudakas  Canada
Hi there,
I saw similar driver configuration at salksound.com veracity ht3 or selahaudio.com RC4 without a built in sub loudspeakers, but don't feel confident to attempt building XO myself using 8" for midrange and 10" for bass.
I will be building 3-way speakers soon using expensive drivers from seas excel line like you mentioned but most likely using a kit supplied by designer.
If someone could share xo drawings for speakers above would be a huge help.
Old 19th October 2005, 04:50 AM   #3
My friend have experience with crossover, but I thought about using a crossover designed by Dave Ellis for the 1810b (in the case of using the Hiquphon).
I don't know if I use the 10'' woofer, or two 8'' woofers... coments?
The SEAS L26 need a big enclosure, what about a 10'' Peerless?
Old 19th October 2005, 05:01 AM   #4
Perhaps more efficient would be 5" for mid and double 8", but I am leaning towards tweeter - 8" - 12" combination.
By the way 1801b is a two way speakers and xo design is proprietary...
3 way loudspeaker Project!Hide this!Advertise here!
line array loudspeaker project daly2k Multi-Way 59 2nd February 2011 04:31 PM
Question - B&W drivers and center loudspeaker project Mrpong Multi-Way 0 15th May 2007 01:53 PM
postmortem of loudspeaker project mazurek Multi-Way 23 21st March 2006 03:24 PM
Fat Margaret Loudspeaker Project ergo Multi-Way 16 22nd July 2003 03:21 PM
Behemoth Loudspeaker Project Ignite Multi-Way 8 19th January 2003 06:02 PM
Copyright ©1999-2017 diyAudio
