Hi!
I know thet the best material to build loudspeaker enclosures is real wood and plywood, but I see very often in diy audio magazines enclosures built with OSB. Has somebody any experiences with OSB? How it's acoustics? Greets: Tyimo |
#2 |
Speakerholic
Tyimo,
There is no best material to build a box from, but I would suggest that only test boxes be made from OSB. It's not a very sturdy board and tends to have a swelling problem at the cuts. Sealing is also difficult. Besides I only see it in 7/16" or about 12mm thicknesses here. Too thin for most applications. If it's being used for diy, then it must be they can't afford or don't have access to better materials. What are you planning to build? Cal |
#3 |
Hi Cal!
I would build a BLH speaker. I can buy here 15-18-21mm thicknesses and the price is also very good. I know it could have swelling problem at the cuts, but the main question is the acoustic properties. Could it be near to the plywood's? Tyimo |
#4 |
I used and know the "sound" of particleboard(19mm), MDF(19mm), Plywood(18mm) and real wood (cherry 25mm).
I could imagine that the OSB's sound is something between Plywood and particleboard.... Basicaly, I don't like particleboard's acoustics... Tyimo |
#5 |
Speakerholic
Is this really oriented strand board? Available in those thicknesses?
If so why not get a piece of the 21 mm, make sure it is well braced including corner blocking and let us know what you think. It may be fine and it's not too expensive. I would still worry about the swelling though as it does seem tough to seal. Cal |
#6 |
It comes in 3/4" for flooring. And for headers it comes in much thicker sections over 2". But the header sizes would really limit your box size unles you felt like joining up sections with a spline or cookies.
Mark
Mark |
#7 | |
Hi!
Greets: Tyimo |
#8 |
Greets!
Ideally, speakers should be constructed with a material that either resonates above or below its passband. If this isn't practical, then greater rigidity (its MOE spec) requires less damping due to acoustic energy decreasing with increasing frequency. The OSB available near me would have to be ~2.44" thick to match 19mm Baltic Birch's MOE, so totally unsuitable for typical alignments unless it's a built-in IMO. That said, a highly underdamped (resonant) alignment can benefit from using such a lossy material, so it may work fine if you can keep it airtight and don't create too many 'hot spots' such as occurs with a lot of bracing or horn folds. Frankly though, having tried this, I find them too 'dead' sounding unless designed with theoretically excessive gain, which isn't the case with every on-line published BLH design I've reverse engineered. As always though, YMMV. GM
Loud is Beautiful if it's Clean! As always though, the usual disclaimers apply to this post's contents. |
#9 |
Hi GM!
Thanks for your detailed answer! Greets: Tyimo |
| PC sound card sound chips | kaluchka | Chip Amps | 6 | 20th June 2011 03:48 PM |
| SE sound vs Ultra Linear sound | flysig | Tubes / Valves | 1 | 9th May 2009 10:21 PM |
| Eighteen Sound (18 Sound) NSD 1095N Compression Drivers and XT1086 Horns | opc | Swap Meet | 6 | 1st May 2009 03:48 AM |
| Sound, Sound, and more Sound - Instractables | Nordic | Everything Else | 0 | 5th March 2008 05:43 PM |
| Roland VS-1 Sound Module - No Sound! | jazzbee | Instruments and Amps | 1 | 3rd March 2006 08:39 PM |
| Page generated in 0.10799 seconds (80.60% PHP - 19.40% MySQL) with 10 queries |
