No, it's not one of those diamond numbers by Accuton, it's this:
http://www.e-speakers.com/products/beengineering.html No real "point" to this post, other than to point out another stratospherically priced driver - maybe the most expensive out there, or darn close to it. Wonder if it sounds a hundred times as good as a $40 SEAS, Morel, etc? Zaph would love this one I'm sure. Just curious - has anyone ever heard these? I'm sure they're superb, but that price tag... Also, while I'm talking about the e-speakers site, has anyone ever heard/built with those Manger drivers? I don't recall ever seeing any posts or designs here - maybe there's a good reason. One more link - these are big and ugly, in my opinion, but for the cost and the designer's comments I have to wonder what they sound like (and it's a kit!): http://www.e-speakers.com/images/ES-TAD-Ref1.jpg Cheers all
Soft Dome |
#2 |
ive heard the mangers a few times from commercial offerings. they sounded decent overall. not a whole lot of top end sparkle, but not harsh. just a bit dead on the top. but relatively open and airy for a full range driver. they were paired with like a 15" or something for a really full range system. it wasnt bad.
#3 |
It looks like something a 2-way ESL/sectioned ESL would probably best the thing at
#4 |
Hi
I have heard the BEEngineering ribbons (the US$3000 ones) with PHL bass support driven by Bel Canto T amps. Was not overly impressed and also saw the $4000 model opened up as the ribbon was burn out or damaged. Feel that the Ravens are better made at this point. Certainly a Accuton, Raven, Nuforce combination with BelCanto Preamp and SACD player sounded much more alive and had more depth. It may have been the Nuforce amps but the price of the BEEnginering units are rather high compared to the Ravens. OK if you really need the lower crossover point on the big BE unit . Still the Raven 3 in its latest version is good down to 650-800Hz? Also the Raven 3.2 is a refined design not a new one ! ! ! Regards AnthonyPT |
#5 | |
Same comments here.
Hear the real thing! |
#6 |
Previously: Kuei Yang Wang
ALE P1750 Supertweeter (above 8KHz), 22Kg weight....
Only $ US 16,000 the pair Add Midrange Driver ALE P4550 Supertweeter (above1.5KHz to 10KHz), 22Kg weight.... Only $ US 16,000 the pair Mid/Hi range units in total only $ US 32,000 for Stereo.... I'm not knocking them BTW, probably very, very good. Sayonara |
#7 |
Are there any commercial applications these are in? Well, this is interesting - how about people post the most expensive available DIY drivers they can find? Woof, mid, tweet, etc. Just to see how high we can go? The "best" driver is always elusive and subjective, but the most expensive might be easier to narrow down. I suppose you can't knock stuff like this, but at some point the cost/benefit ratio goes way off kilter, and way out of reach for the average buyer, and just about all DIYers.
Soft Dome |
#8 | |
Konnichiwa,
I'll just post "how high" I went. My own speakers at home use a pair of 8" "fullrange" drivers (read that as drivers intended to be operated without crossover) that retail at US $ 2,700 the pair (or around $ 170 per inch). And I think they are worth every cent. In a reasonable size open baffle and depending on the fieldcoil voltage they manage 50Hz - 10..15KHz. So added on are a pair of Visaton TL-16H Horn supertweeters which bring us another $ 500 into the bargain. Finally a cute little sub with a pair of Pro Audio 12" Woofers (these are the weakest link and on the endangered species list right now - I fancy something with the numbers reversed) in a sealed box, probably with Plateamp another $ 500 or so. Well, that is a system with around $ 3,700 in drivers and plateamp only. Add powersupplies for the fieldcoils, enclosures, acrylic baffles etc. and there are at least $ 6,000 in materials in that speaker system right now, for what is basically a 1 1/2-1/2 Way system. I do not think I have heard much that can match what my system does. Closest so far is a pair of MEG RL-901K, which incidentally cost more than twice that, are pro studio monitors and a are notably edgier and somewhat more fatiguing, never mind butt ugly.... Sayonara |
#9 |
anyone have any experience with Michel Fertin drivers ?
preferrably in comparison with the Supravox's ? http://www.fertin-acoustic.com/ and some example specs here: http://www.jlbcreations.com/fertin/i...ourbes20ex.pdf |
#10 |
I'm thinke'n I want to build a line array !!!!
| Why not a ribbon tweeter instead of a horn tweeter? | Curly Woods | Full Range | 9 | 15th July 2009 04:09 PM |
| Tweeter help for Miller & Kreisell Tweeter 17500 | merajsalek | Multi-Way | 4 | 3rd September 2008 03:41 AM |
| Linaeum Dipole Tweeter as a Super tweeter? | ktuuri | Planars & Exotics | 5 | 17th June 2008 06:52 PM |
| Round radiating tweeter, aka "Enterprise 1" tweeter! | tubee | Multi-Way | 39 | 13th May 2007 09:03 AM |
| Titanium tweeter vs Ribbon tweeter | goldyrathore | Multi-Way | 14 | 17th May 2004 07:21 PM |
| Page generated in 0.14589 seconds (82.18% PHP - 17.82% MySQL) with 11 queries |
