Vacuum loudspeaker
Vacuum loudspeaker
Old 15th October 2005, 06:02 PM   #1
Soulwax is offline Soulwax  United Kingdom
Default Vacuum loudspeaker
Possibly a silly question but here goes anyway.
What would happen if you were to take an acoustic suspension enclosure, make it airtight, and then evacuate the air inside to create a partial vacuum? What would happen to the rear wave since it would have no medium through which to propagate?
Would this reduce cabinet colourations?
Old 15th October 2005, 06:23 PM   #2
SmarmyDog is offline SmarmyDog  United States
SmarmyDog's Avatar
Here are some recent thoughts...
http://www.diyaudio.com/forums/showt...374#post741374
-Casey Walsh
Old 15th October 2005, 06:41 PM   #3
Tweeker is offline Tweeker  United States
One thing that will happen is that the cone will no longer be resting at the mid point of a normal suspension/surround but will be pushed well into the cabinet side. Using a gas of different mass but the same pressure wont have this.
Old 15th October 2005, 07:08 PM   #4
Audiophilenoob is offline Audiophilenoob  United States
Default Re: Vacuum loudspeaker
the rear wave wouldn't exist if there was a vacuum there...
I don't see how this is possible though given that speakers themselves leak air
Old 15th October 2005, 07:14 PM   #5
rcavictim is offline rcavictim  Canada
rcavictim's Avatar
For one thing it would make it much easier for incredibly degenerate, stupid people who attend stereo stores to push in and damage the dust caps in the middle of exposed loudspeaker drivers!
Old 15th October 2005, 07:21 PM   #6
Good link Casey. I obviously have some reading to catch up with.
Old 15th October 2005, 08:27 PM   #7
454Casull is offline 454Casull  Canada
Well, multiply the pistonic surface area of the cone by atmospheric pressure. That number is the force applied to the cone [inward].
I don't think any kind of speaker can handle that kind of ridiculous abuse.
EDIT: However, if you do have a cone/suspension that can handle it, I believe you could achieve a response like that of an infinite baffle (but in sealed enclosure with a volume of virtually zero).
Old 15th October 2005, 09:33 PM   #8
chainenoble is offline chainenoble  Canada
you would need over 500kgs of force to move a 12 woofer.thats one big magnet and alot of watts
Old 15th October 2005, 10:44 PM   #9
joe carrow is offline joe carrow  United States
Send a message via AIM to joe carrow
Actually, it would not necessarily take a lot of force to move it. You would just need a suspension with the right spring constant and a lot of play.
Think of it this way- if you had a really long spring (hundreds of feet), it might have 500 pounds hanging from it, but another ounce of force could move it an inch or more. That's assuming a linear spring constant.
I think it sounds reasonable as far as the physics of it go, but I'm not sure if you could arrange a geometry that would be able to take advantage of it. Perhaps a really funky spring constant could do it; or a servo motor with a DSP controlled displacement/force curve.
I wouldn't call the vacuum woofer a physical impossibility yet, but I doubt it's within the range of the DIY community, nor will it be within the next 10 years.
Edit- change units to metric
Disclaimer- I am a fan of science fiction
Old 1st August 2007, 01:07 PM   #10
APi is offline APi  Finland
What if you make loudspeaker box U-shaped, put some elastic foil on it and suck the air away. The foil bend inside the box until it has enough tensile elongation. Pressure is "only" 1/5-1/10 what you have in bicycle wheel. Not anything that the right material wonīt stand.
And there you have the "cone". Box can be very thin, very tall and/or wide.
But how to move the "cone" since itīs not stiff enough for a point force?
ESL?
Vacuum loudspeakerHide this!Advertise here!
DIY loudspeaker vs. factory built loudspeaker keyser Multi-Way 130 14th June 2016 10:21 PM
Bad vacuum? astouffer Tubes / Valves 4 28th November 2008 10:55 AM
Vacuum Tube Pre O.C.L. gianmaria Tubes / Valves 13 16th February 2006 06:32 PM
vacuum enclosure Shpoop Multi-Way 22 28th July 2004 12:35 PM
DIY Vacuum tube amp turbo_h4 Tubes / Valves 2 1st July 2004 01:48 AM
