Old 14th October 2005, 02:01 PM   #1
Default Center channel question
I have been reading about shielding your center channel speakers but what I can not find out is any information on why or how to do this.
Old 14th October 2005, 02:11 PM   #2
The best way is to use drivers that are shielded.
Old 14th October 2005, 03:23 PM   #3
Speakerholic
Cal Weldon's Avatar
The other way is to add "bucking" magnets, glued to the back of the existing magnet. They can be bought from PE and other places.
I can't help with what magnets are used to buck what drivers. I have heard that you need 80% the strength of the existing magnet to effectively shield but hopefully others will chime in with more accurate numbers and what glue to use.
Cal
EDIT: The shielding is only needed if you have a CRT type TV and the centre channel speaker is close enough to it that the screen is affected by the magnets of the speaker.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Need center channel help Ryan_Mc Multi-Way 0 12th February 2009 03:36 AM
center channel?? wicho Multi-Way 1 25th October 2008 01:01 AM
Center channel 66Panel Multi-Way 0 25th August 2008 03:48 AM
T-amp for Center Channel? atleer Class D 3 6th August 2007 04:56 PM
Center channel using TB flaevor Multi-Way 2 3rd May 2005 08:27 PM
Page generated in 0.07843 seconds (72.62% PHP - 27.38% MySQL) with 10 queries
