Old 12th October 2005, 11:01 PM   #1
rjb is offline rjb  New Zealand
Default Leak 600 repair
I have been asked to repair a Leak Sandwich 600 loudspeaker.
This is a sealed unit, about three or four cub ft.,with a bass unit, 12" cone of polystyrene, with aluminium stressed skin, a 3" midrange of similar construction, and plastic dome tweeter. Appropriate rather complex crossover.
It was one of the better sounding "large bookshelf" units from the late '60's I think.
The problem was one blown midrange- the voice coil having what looks like a corrosion break in the centre turns.
Actually this unit is nicely designed with an aluminium basket that simply baynots onto the magnet assembly. The basket carries both spider and cone surround. both solidly glued on. This makes it difficult to rewind the voice coil.
A further issue is the cone surround, which is what appears to be loose cambric, flat, not shaped in any way, treated with a black rubberised compound. The cone, (not in the magnet assembly)when pushed moves freely in one direction, but not the other. That is, the cone seems to be sitting off the suspension centre.
So does anyone have information on these, and where can I source a replacement or substitution?
Thanks for your help.
Old 14th December 2006, 07:38 AM   #2
Hi there,
How did you end up with the Leak 600 repair?
I have just bought a pair of these and working out what needs fixing, but I am very much a novice on thing such as this.
So far it looks like the following problems:
1. tweeter is not working in one box (blown?)
2. one bass unit has got corroded metal surround (white powder)
3. both bass units exhibit bubbling of the cone outside layer.
4. both bass units have black surround starting to come loose from the metal surround in some places
5. One bass unit gives a slight buzzing sound (coil rubbing?)
Any advice you can offer would be most appreciated.
Leak Sandwich Ropie Multi-Way 35 17th November 2010 11:49 PM
Leak / Dynaco DIY KJ2005 Tubes / Valves 9 6th June 2008 02:00 AM
Leak Tl/12+ Psychobiker Tubes / Valves 4 6th March 2008 09:06 PM
Leak tl/25+ OPT selection avxt Tubes / Valves 12 21st September 2004 01:22 AM
Motorboating in leak 20 bronto64 Tubes / Valves 5 13th August 2004 10:49 AM
Page generated in 0.07308 seconds (72.32% PHP - 27.68% MySQL) with 10 queries
