A friend gave me two tweeters.
Does anyone know what brand or type they are. Kind regards Johan Jonker |
#2 |
Speakerholic
Johan,
You'll have to provide as much information as you can on them. Where did your friend get them? Are there any numbers on the back or anywhere? What are they made of? They appear to be a cast material. Cal |
#3 |
I would gues it is a ribbon tweeter working acording to "heil motion transformer" principle. Never heard one - but should be top shelf stuff
#4 |
They are old versions of the smaller ESS air motion transformers. Sensitivity is pretty high at around 95 to 96 db/2.83V/m. Impedance is constantly flat around 6 ohms.
The newer ones have a lower impedance and lower efficiency but can also be crossed lower also a lower. I have measured them and used them and can advise you that they do need some form of correction. Without correction they sound a bit harsh with little top end extension. Onces smoothed out (notch filter for the bump between 7Khz and 13Khz) they sound pretty good, at least better than most dome tweeter I have heard, but I can advise a crossover frequency of at least 4kHz, lower is possible but higher sounds better. |
| Why not a ribbon tweeter instead of a horn tweeter? | Curly Woods | Full Range | 9 | 15th July 2009 04:09 PM |
| Tweeter help for Miller & Kreisell Tweeter 17500 | merajsalek | Multi-Way | 4 | 3rd September 2008 03:41 AM |
| Linaeum Dipole Tweeter as a Super tweeter? | ktuuri | Planars & Exotics | 5 | 17th June 2008 06:52 PM |
| Round radiating tweeter, aka "Enterprise 1" tweeter! | tubee | Multi-Way | 39 | 13th May 2007 09:03 AM |
| Titanium tweeter vs Ribbon tweeter | goldyrathore | Multi-Way | 14 | 17th May 2004 07:21 PM |
| Page generated in 0.07765 seconds (73.03% PHP - 26.97% MySQL) with 11 queries |
