Old 10th October 2005, 11:58 PM   #1
Default Kef 105.3 assembling
Dear friends,
I have made a pie, I have gotten off completely the 105.3, doesn't remember anymore now the connections. I thought it was easy to reassemble her, instead I don't understand if the woofers are in phase, if the mid low they go to out phase.
To ear I have climbed on the woofers between them in out phase, the mid low in comparison to the woofers in out phase, so it seems to play well.
Him UNI-Q besides that he has not been gotten off, he has always played with a strong exaltation toward the 3 KHzes with very nasal sound. Now from when I have reversed the phase on the TW it seems to play very well and linear. do I ask you besides, is it possible that in this crossover they are only there condensers electrolytes not polarized? they are not too much cheap? what does it mean LL initials on the condensers from 7 mFs used for UNI-Q? (they seem normal electrolytes not polarized). Help me, SANDOR626 from Italy
Old 11th October 2005, 05:01 PM   #2
The wires to each of the drivers are colour coded. At KEf we always used a consistent code to signify which colours were for tweeter, midrange etc, and also which were positive and negative.
Unfortunately I no longer remember what is what.
Let me know what colours you have and I may possibly remember and be able to help.
Also, the xover is built on a printed circuit board that is attached to the rear panel. The circuit board should be screen printed with the details of the connections.
If you remove the panel you should have the info you need, but this time ta.ke pictures as you dismantle, just in case :-).
Also, I can confirm that all the capacitors are non-polar types.
Andrew
Old 29th September 2007, 02:46 PM   #3
up
Old 30th September 2007, 06:50 PM   #4
hello,
is not there anybody that can send photos of the wiring?
Old 1st October 2007, 11:49 PM   #5
Inductor's Avatar
Default Kef colour code
Look here
Old 2nd October 2007, 12:15 PM   #6
Hello,
AndrewJ have posted :
"The KEF wiring scheme used the following colours:
Blue: HF+
Brown HF-
Yellow MF-
Green MF+ ".
But Clem_o have posted another code , where
the blue color is negative.
I don't know whom to believe to !
Old 2nd October 2007, 06:54 PM   #7
Inductor's Avatar
The previous colour code that I posted is from 105.2. I am not sure what colour code was used, in what model/year. So better check one by one.
Old 3rd October 2007, 06:56 AM   #8
hello,
I don't succeed in files attaching , perhaps because I don't have an enough number of posts.
otherwise I would have sent the scheme of Clem_o
Sandro
Old 3rd October 2007, 06:58 AM   #9
I have succeeded there
Old 3rd October 2007, 10:00 AM   #10
Inductor's Avatar
The colour codes are not the same.
You have a 36 component crossover?! What are you listening to, Kraftwerk?...
Tried assembling my own crossover...why didn't it work? PoorSound Multi-Way 5 16th February 2008 07:02 PM
Assembling Aria Crossover, some help needed pjpoes Multi-Way 4 11th January 2007 01:21 AM
Finishing assembling a driver? Destroyer OS. Subwoofers 7 10th January 2006 10:12 PM
Assembling Neutrik Connectors soundNERD Parts 10 19th April 2005 02:15 AM
is it worth it assembling ur own stereo mixer? Ze Instruments and Amps 1 7th May 2004 09:05 PM
Page generated in 0.11388 seconds (78.97% PHP - 21.03% MySQL) with 11 queries
