Old 10th October 2005, 07:58 PM   #1
owdi is offline owdi  United States
owdi's Avatar
Default Need crossover advice/ideas - Dayton planar and ref mid
First, the speakers:
DAYTON PT2B-8 PLANAR TWEETER
DAYTON RS150S-8 6" REFERENCE SERIES SHIELDED WOOFER
This is my first speaker project (besides subwoofers), so I'm trying to keep things simple. The plan is to use one tweeter and one woofer per side, and a 2nd order crossover at 3000hz.
Some questions:
I understand I will see a 3db bump in response at the crossover frequency because both drivers will be down by 3db. I would rather have a dip in response than a peak. Is there any reason why I couldn't cross the mid at 2200hz, and the tweeter at 3000hz, so they meet at 2600hz where they are both around -6db?
When attenuating the tweeter, will a series resistor be enough? I don't think I need an lpad because the planar tweeter is a resistive load.
Last question, besides using a higher order filter, is there anything I can do about the nasty peaks the Dayton mid has at 6khz and above?
Thanks for any advice. Please keep in mind I'm not going for perfection, just something that sounds good. I will leave the crossover outside the speaker so I can tweak things.
Dan
Old 13th October 2005, 02:45 AM   #2
Zick is offline Zick  United States
I'm trying to build some 2-ways and asked George at North Creek Music about using his D25 06 tweeters with some Monitor Audio Gold 6.5 woofers and he stated "We usually specify a 2nd order network at around 1800 Hz because with our tweeters this is the best sounding way. 6" woofers usually begin to sound a bit rough above 2kHz."
So you might want to re-thing your 3k crossovers.
Old 13th October 2005, 09:36 AM   #3
Pluto is offline Pluto  Germany
Hi Dan,
some answers:
- Usually, drivers are crossed over at their -6 dB points, but make sure that their relative phases are right, so that the sum of the SPL curves yields a linear total response. The best way would be to use SPL and phase data measured in the cabinet and to do a simulation. A crossover point of 2.6 kHz makes sense, taking into account the response curves and the distortion.
- A series resistor will work fine.
- You might try a relatively broadband notch filter centered at 9 kHz to suppress the resonances.
Peter
FS-16 Dayton Pt 2 Planar tweeters Badge Swap Meet 0 4th December 2007 08:26 PM
first total crossover...advice...dayton 7" alu. and hi-vi k1 nerd of nerds Multi-Way 22 8th October 2006 12:05 AM
Zaph: DAYTON PT2B-8 PLANAR TWEETER 69stingray Multi-Way 4 8th August 2006 05:25 PM
Dayton PT2B-8 planar tweeter mazeroth Multi-Way 5 26th November 2004 09:49 PM
dayton pt2 planar tweeter huj69 Planars & Exotics 8 22nd December 2001 03:25 AM
Page generated in 0.07839 seconds (69.80% PHP - 30.20% MySQL) with 10 queries
