Old 10th October 2005, 09:03 AM   #1
Puggie is offline Puggie  United Kingdom
Default mixing series and parallel Xovers in the same design
would it be possible/advisable to build a crossover similar to this:
I currently have
midbass to midrange horn with a passive 24dB/Oct LR crossover at 1250Hz, this will be dropped to about 600Hz shortly (4th order LR still)
I could do to add some supertweets because the horns start to roll of at 16kHz and have some dome breakup around 12kHz. could I use my current Xover and instead of using the highpass to drive the Horn, use the highpass to drive a 1st or 2nd order series Xover (at about 8-14kHz) which would then have the horn and supertweet driven off that?
is there a problem with cascading series and parallel filter like this?
Three 10" 4Ohm subs, wired in series or series-parallel? Nagamitsu Car Audio 24 10th May 2009 03:24 AM
series or parallel? medicman Tubes / Valves 5 22nd January 2009 04:42 PM
using series and parallel Xovers in the same design, is it ok? Puggie Multi-Way 3 3rd June 2005 05:25 PM
Mixing desk design argonrepublic Music 2 6th May 2005 02:57 PM
series Vs parallel passive Xovers Puggie Multi-Way 10 19th April 2005 04:06 PM
Page generated in 0.06699 seconds (70.27% PHP - 29.73% MySQL) with 10 queries
