Old 9th October 2005, 03:04 PM   #1
xyrium is offline xyrium  United States
Default Inductive coupling
Am I going to have problems with a layout like this? The largest inductor value is 1.7mH. Thanks for any advice you guys may have!
Also, I was hoping to simply use a twisted pair (from Cat VI Ethernet cable) to do the connections to the speakers and inputs, does anyone see a problem with using a twisted pair as a single conductor? Also, is there a gauge calculator/formula out there that will help me deterrmine what the combined gauge of two 24ga cables is?
Tks,
Paul
Old 9th October 2005, 04:20 PM   #2
Ok, updated so the inductors are hole-to-hole, or hole to outer circumference.
Old 9th October 2005, 11:56 PM   #3
David Gatti's Avatar
Your first pic is better - they should not face the same direction.
Old 10th October 2005, 03:30 AM   #4
Thanks David. I was under the impression that they should radiate toward anything via their circumference. Thus, the top and bottom of an iductor would have the same magnetic field as the coil's direction.
Paul
Where to by inductive wirewounds? Tweeker Parts 5 14th February 2009 04:43 AM
Inductive coupling between power supply inductors pjpoes Parts 0 21st May 2007 05:22 PM
Non inductive resistor ostie01 Parts 23 4th June 2006 09:03 PM
Is this resistor inductive? Jay Pass Labs 11 5th April 2003 02:24 PM
Non-Inductive Resistors rborer Solid State 9 3rd September 2001 09:47 PM
Page generated in 0.08154 seconds (72.00% PHP - 28.00% MySQL) with 11 queries
