Hi guys, How do you if a tweeter is bad?
#2 |
Define "bad".
#3 |
just another
In my case they usually emitted a bad smell and stopped making any noise
finaly don't rule out your amplifier (or amplifier/speaker combination) as the source of the problem! But as David said define bad, I could have just told you a whole pile of irrelevant information Tony. |
#4 |
Thanks guys for your responses, when I said bad is not sound at all, just wanna be sure the tweeter is bad, not the crossover, because I just connected them and nothing happened. Thanks
#5 |
just another
In that case if you make sure the amp is turned right down you could connect the tweeter directly without the crossover and only turn the volume up a tiny amount, if it starts to make any noise you know you have a problem with the crossover
Tony. |
#6 |
I would do it the other way round. Connect the mid driver to the tweeter output of the crossover. It will sound rubbish, but will at least be a bit safer than connecting the tweeter direct to the amp!
Al I conceive of nothing, in religion, science or philosophy, that is more than the proper thing to wear, for a while. Charles Fort |
#7 |
just another
good thinking Al
Tony. |
#8 |
Thinking out of the box is good, but it sometimes mean you miss the obvious answer.
The very easiest way would be to put a meter, (set to resistance), across the tweeter and see if you get continuity!
#9 |
just another
#10 | |
| ARTA tweeter measurement problems | doug20 | Multi-Way | 9 | 22nd June 2009 12:38 PM |
| Tweeter problems - how to identify | rotebailer | Multi-Way | 1 | 9th May 2009 04:05 PM |
| Tweeter help for Miller & Kreisell Tweeter 17500 | merajsalek | Multi-Way | 4 | 3rd September 2008 03:41 AM |
| Linaeum Dipole Tweeter as a Super tweeter? | ktuuri | Planars & Exotics | 5 | 17th June 2008 06:52 PM |
| Problems with ribbon tweeter and ZEN V4 | Selfmade | Pass Labs | 9 | 10th October 2002 10:51 PM |
| Page generated in 0.09648 seconds (88.13% PHP - 11.87% MySQL) with 10 queries |
