I would like to use 2 16ohm speakers parralled for midranges but am not sure if that will throw off the crossover point. I have some premade passive crossovers I would like to use. I know using 1 16ohm driver will change the frequency but If 2 are parralleled will they both be at that different(higher/double) frequency or at the normal 8ohm frequency?
I dont have the drivers yet to test but if this will work I will order them. Will go active later but passive I find much easier for testing/setting up. |
#2 |
Speakerholic
Two 16 ohm drivers paralleled will give the same crossover point as one 8 ohm
#3 |
Thank you. That makes it much easier for me then.
| 16ohm 3way | lochness | Multi-Way | 6 | 20th November 2007 12:26 AM |
| WTB: 16ohm Lpad | justpoor | Swap Meet | 0 | 21st February 2007 09:52 PM |
| How many amperes for a parallelled lm4780 | jaste | Chip Amps | 2 | 24th January 2007 06:00 PM |
| BIB's and WR125-16ohm | mrpopgun | Full Range | 0 | 10th November 2006 06:57 PM |
| Effective load impedances – SL Phoenix - drivers parallelled | rick57 | Multi-Way | 0 | 12th April 2006 02:17 PM |
| Page generated in 0.06534 seconds (69.84% PHP - 30.16% MySQL) with 10 queries |
