Old 6th October 2005, 02:01 AM   #1
Default Horn Mouth Diffraction
Dear all,
It is rather well understood that a finite aperture of a horn/wave-guide causes diffraction effects, [1]. However, neither this reference nor another paper [2], which at least tangentially touches on this issue, gives any insight on computation of a mouth shape that would give an optimal (whatever the criteria) diffraction.
I am also aware of the work of Jean Michel Le Cleac'h [3], but this appears to be concerned with the entire horn contour, and not only the mouth shape. As such, it appears inapplicable to a situations, where a horn contour is pre-determined, e.g., constant directivity.
I would appreciate if anyone, who aware of any theory/papers/software dealing with this issue, could post references.
Thank you,
M
[1] Geddes, E., R.: "Sound Radiation from Acoustic Apertures." JAES., vol. 41, pp. 214-23 (April 1993)
[2] Henwood, D.J.: "The Boundary element method and Horn Design, JAES, vol. 41, pp. 485-496 (June 1993)
[3] http://ndaviden.club.fr/pavillon/lecleach.htm
Old 6th October 2005, 05:17 AM   #2
al2002 is offline al2002  India
al2002's Avatar
The best reference, in fact the only reference I know of, on this topic is Geddes' book, "Audio Transducers". I strongly recommend it.
It can be ordered directly from his site: www.gedlee.com.
A sample calculation may be seen here:
http://gedlee.com/downloads/Appendix_A.pdf
Hope this helps.
Old 6th October 2005, 05:53 AM   #3
Dear al2002,
thank you for the reference.
However, it seems to me that we are micommunicating because the link that you have posted treats calculation of a wave propagation throug a wave-guide assumed to be conical; therefore, without mouth flare.
The only comment related to my inquiry is on p. 302: ". . . waves reflected . . . can be reduced by radius'd (flared) mouth treatment as we discussed in Sec. 6.6."
Could you tell me if Sec. 6.6. contains any theoretical derivation of the flare or just states to do so?
M
Old 6th October 2005, 06:42 AM   #4
Cloth Ears's Avatar
Is this (http://www.users.onaustralia.com.au/...phd/thes.ps.gz) along the lines of what you're looking for? I haven't read it yet as I haven't been able to grab the printer for long enough.
Jont.
"It is impossible to build a fool proof system; because fools are so ingenious."
Old 6th October 2005, 10:07 AM   #5
jomor is offline jomor  Greece
jomor's Avatar
Default Re: Horn Mouth Diffraction
Originally posted by mefistofelez
Dear all,
http://www.nutshellhifi.com/library/...r-design1.html
Look at the Horn paragraph. In fact, the whole article is a "must read".
Old 6th October 2005, 10:45 AM   #6
pooge is offline pooge  United States
http://db.audioasylum.com/cgi/m.mpl?...pooge&session=
Old 6th October 2005, 03:32 PM   #7
al2002's Avatar
Dear al2002,
M
No miscommunication. The link was only given to illustrate the standard of the book. It does not, of course, show a diffraction calculation.
M
Yes, it does.
Old 6th October 2005, 03:38 PM   #8
"Earl, in your waveguide paper you dealt with a radius at the baffle, but didn't specify its curvature. Can you eloborate on this?" The radius should really be as large as a wavelength of the lowest frequency, but a rule of thumb says that it should be no less than 1/4 wavelength at the lowest frequency of waveguide use. This will diffract a lot less energy, but still a significant amount at the lowest frequencies.
Old 6th October 2005, 06:01 PM   #9
Earl Geddes uses a 2" radius on his waveguides
Old 6th October 2005, 06:07 PM   #10
al2002's Avatar
I believe it is the cabinet edge radius which is 2". The waveguide itself has a 4" flare at the mouth.
Also, in response to an earlier post, Geddes' recommends a lambda/2 flare at the mouth.
Horn mouth bubble size MaVo Subwoofers 1 25th February 2009 11:59 AM
Horn mouth venting to the floor Tyimo Full Range 8 22nd February 2008 06:53 PM
rear horn mouth area big_kahunah Full Range 1 16th August 2005 01:35 AM
Screen in horn mouth? Stocker Multi-Way 7 9th March 2005 09:39 AM
Horn speaker w/variable throat & mouth bbaker6212 Multi-Way 1 1st August 2003 07:27 AM
Page generated in 0.11624 seconds (79.44% PHP - 20.56% MySQL) with 10 queries
