Old 4th October 2005, 09:10 AM   #1
Hayden is offline Hayden  Australia
Default Dampening cloth
Will the layout of the cloth make or break a good speaker?
I have seen good quality manufactures lay the cloth nicely on all sides in the box and I have seen them just stuff it in, does it make a difference to sound quality?
Old 4th October 2005, 01:37 PM   #2
DirkD is offline DirkD  South Africa
Provided that the air flow to the port/s is not retricted - no.
Dirk
Old 4th October 2005, 01:57 PM   #3
Very true,
But it’s a sealed box
How much do I put in, it stands 100cmH x 23D x 30W
I suppose enough to fill it so there are no walls showing
Its very thick stuff too almost 10cm thick
Old 4th October 2005, 02:00 PM   #4
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
The damping cloth has the max effect at those places in the box where the air velocity is max. That generally is when the standing wave modes of the box are excited, with the max air velocity AWAY from the box panels. The max velocity locations are mid between panels, 1/3 between panels, 1/4 between panels etc depending on the harmonics of the resonants. Higher harmonics have lower amplitude, so the bottom line is that max air velocity normally occurs in the middle of the box. Lining the box panels with damping cloth therefore has minimal effects.
Jan Didden
PS I assume you mean "damping" as in to suppress movement. "Dampening" means make damp, make wet.
/Another new issue: Linear Audio Volume 3!
Dampening a must? squidbait Multi-Way 22 2nd April 2004 12:07 PM
help on dampening please welly_59 Multi-Way 5 25th November 2003 02:35 PM
DIY Dampening Radik Multi-Way 17 18th November 2003 04:53 PM
dampening Stryder Digital Source 39 7th January 2003 01:42 AM
Dampening in a car dsanders Multi-Way 4 29th October 2001 03:31 AM
Page generated in 0.07137 seconds (69.05% PHP - 30.95% MySQL) with 10 queries
