Old 4th October 2005, 04:11 AM   #1
Send a message via AIM to Binaural
Question Reccomendations on speaker build
Hey all, first I must say i LOVE the wealth of information on this site!
Ok now down to business, I'm looking to build my first set of speakers (actually 3 LCR configuration) I have a pretty limited area to put them so i'm looking at bookshelf size. I'm really going for maximum sound quality. Really i'm trying to gather ideas here so if you have any reccomendations throw them at me!
I guess i should state that i'm an audio engineer by trade so i have a good understanding of acoustics/electronics and have access to a decent wood working shop to make the enclosures.
Thanks everyone!
Old 4th October 2005, 04:27 AM   #2
Send a message via AIM to joe carrow
I think you'll need to add some more details to narrow it down some. To consider:
-budget
-size (be specific)
-listening pattern? (home theater, music, studio, etc)
-amplifier wattage, number of channels, etc.
-musical taste
-commercial offerings you'd like to imitate
I think there's a lot on here if you search thoroughly.
Old 4th October 2005, 03:32 PM   #3
Sorry for the lack of specifics, see if this is a little more help.
As far as size of the drivers, i think i've decided on a 2 way setup with no larger than a 6" low range. I'd really like to use a ribbon tweeter because i like their transparency and upper harmonics, all in a small ported box.
The speakers would be used in a home theater setup but i also listen to a lot of vinyl, dvd-audio, SACD, and binaural recordings that would be stereo only.
Powering these is a Sony V333ES with 6 channels and 120 watts per channel. Eventually i will be upgrading to 6 homemade triode/pentode monoblocks, so i'd like to build one that would be most compatable with both.
I listen to everything from Joe Satriani to boroque played on period instruments.
As far as speakers i'd like to emulate, perhaps the Jean-Marie Reynaud Twin Mk.III loudspeaker minus the dual voice coil woofer. I love the stereo image of these speakers and how true to life they are, or maybe the PSB New Stratus Mini for realism.
Is this asking too much? I intentionally left out $$ so i don't completely limit myself at first. Also to get that kind of sound is the ribbon tweeter the right way to go?
Old 5th October 2005, 12:04 AM   #4
frugal-phile(tm)
planet10's Avatar
RAW HT1s? CSS WR125 + Al's version of the Aurum Cantus 2Gsi.
dave
community sites t-linespeakers.org, frugal-horn.com ........ commercial site planet10-HiFi
p10-hifi forum here at diyA
Old 5th October 2005, 04:25 AM   #5
Hey Dave,
I've done some research on the Aurum Cantus and it looks great so i think i've found my tweeter. Now the WR125 seems to be a bit small (in size yes, but what about sound?) how does this compare to say a swan m6a?
Now on to the nitty gritty. Enclosure design, what materials work the best, MDF or solid wood? Crossovers, i was looking at just building a good one, do you know where i can find plans for one? Thanks for helping me get this far.
Old 5th October 2005, 05:26 AM   #6
frugal-phile(tm)
planet10's Avatar
Because of the XBL technology it performs much larger than its size*. Because it is small it reaches up higher. The price paid is its efficiency.
*(ie i think of the Exremis 7" in the same places i'd think of a 10")
It sounds very good.
dave
Old 5th October 2005, 03:08 PM   #7
Speakerholic
Cal Weldon's Avatar
MDF or solid wood?
I would recommend plywood
Cal
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 5th October 2005, 03:17 PM   #8
xyrium is offline xyrium  United States
Hey Dave,
The AC ribbons are nice, however it sounds like you should do a predesigned build. That's what I'm doing for my first speaker. AFAIK, MDF is the way to go, especially if you're going to do your own veneer. MDF (someone please correct me if I'm wrong) is better damped (lower resonance) than solid, or ply wood. It creates a TON of dust when you route and cut it though.
I'm doing Zaph's L15/27TDFC design right now. I highly recommend you check out his site for a nice design on the L18/27TBFC all metal system which sounds like it will fit your description quite well.
www.zaphaudio.com
Rgds,
Paul
Old 5th October 2005, 03:21 PM   #9
Then again, if you're an audio engineer and have access to a good deal of space and tools, I would have to agree with Planet 10, because I find those ribbons so darned intriguing. Though I would still go with MDF (1" front, 3/4 everywhere else).
Old 5th October 2005, 07:30 PM   #10
frugal-phile(tm)
planet10's Avatar
Agreed... unless you really know what you are doing
I've given up on MDF. Use plywood. We get all the free MDF we could ever use and will still go out and buy a sheet of Baltic Birch, using MDF only for less critical subwoofers.
We did matching bi-poles with plywood & MDF, and, to the ones with better trained ears, the plywood was clearly superior. Some preferred the MDF, and the reasons why shed some interesting light on people's perception of what was happening (i keep threatening to editorialize on this)
dave
Reccomendations for a service facility. marsupialx Solid State 0 22nd July 2009 01:51 AM
Looking for enclosure reccomendations soundsinthestix Full Range 10 25th November 2008 09:51 PM
Head unit reccomendations rocko1290 Car Audio 13 31st August 2006 09:35 PM
Headphone reccomendations Raj1 Headphone Systems 15 18th May 2003 06:53 PM
Amp reccomendations? gruvenbob Pass Labs 6 23rd August 2002 06:07 PM
Page generated in 0.33689 seconds (31.18% PHP - 68.82% MySQL) with 11 queries
