Old 1st October 2005, 02:21 AM   #1
bowdown is offline bowdown  Australia
Question Please help.
Hi i was just wandering if someone can help me with this cross over, all i want is to know what the cut off frequncies are for the mid and tweeter and also if possible what type of alignment it is.
Any type of help would be really greatfull.Is this any good for these drivers?
Here is the link to the crossover
http://www.audiocomponents.nl/speake...rrekt-xt_4.htm
Bowdown
Keep up the diy spirit!!
Old 1st October 2005, 09:24 AM   #2
anyone?? just the crossover frequencies?? please??
Thanx
Old 1st October 2005, 01:22 PM   #3
just another
wintermute's Avatar
Hi Bowdown without knowing the impedance of the drivers it's not possible to work out the crossover freq.... and I'm not just talking about 8 ohm nominal, I'm talking about the actual impedance at the crossover freq.
Looks like it is a first order with impedance comp on the woofer.
If the impedance was 5.8 ohms for the woofer (not unreasonable especially with imp comp) then the crossover freq would be about 600Hz..... note that such a low crossover freq could be done to compensate for baffle step.
the tweeter has a 3rd order butterworth filter on it... I used it with my tweeter in sw and it looks like it is crossing at about 2Khz (very very hard to tell) impedance of my tweeter is about 7.5 ohms at that freq..... I wouldn't rely on this at all probably would be better to model with a completely flat freq graph then it should be easier to see the crossover freq, but again without the impedance it's not possible to tell.
edit: here is the simulation in speaker workshop with a totally flat starting fr.... note that these values don't give a typical slope, it has more than likely been tweaked for the tweeters response... also this is using the impedance curve of my morel DMS37 tweeter. from this it looks like the crossover freq is a bit higher too, but that would depend on the driver it was intended for
Tony.
Any intelligence I may appear to have is purely artificial!
Some of my photos
Old 3rd October 2005, 01:10 AM   #4
Thanx for the info wintermute. Do you think its worth trying the xover anyway? I have the components on hand already. Thanx again.
Bowdown
Old 3rd October 2005, 01:24 AM   #5
Speakerholic
Cal Weldon's Avatar
bowdown,
Yes, give it a try and let us know how it sounds.
Cal
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Old 3rd October 2005, 02:24 AM   #6
just another
wintermute's Avatar
If you have the parts you don't have anything to loose , are you also using the same drivers that the schematic shows??
Tony.
Some of my photos
Old 3rd October 2005, 07:12 AM   #7
Yeah guys no worries i will post some details once im done. Yeah i am using the same drivers.Its going to take a while to build as i am going to be using translamination. I have started building the enclosures but im doing it bit by bit as i dont have many clamps! I want to tune the box a little differently(slightly smaller box) i will end up with a little less low end but i can always build a sub. I will be using Solen Caps and Hepta-litz air core inductors from Solen as well. Im sooooooo excited hope it turns out well.
Thanx for all the replies
Bowdown
Page generated in 0.09723 seconds (77.18% PHP - 22.82% MySQL) with 10 queries
