Old 1st October 2005, 02:20 AM   #1
Default Crossover Modification
I've got a crossover designed for a very expensive 8 ohm nominal tweeter. While I'm saving up for the tweeters, I'd like to use my current tweeters with my new crossover. My current tweeters are 6 ohm nominal. Can I just put a 2 ohm power resistor in series with my current tweeter and maintain the cutoff frequency of the crossover?
-Jim
Old 1st October 2005, 05:05 AM   #2
Speakerholic
Cal Weldon's Avatar
Hi Jim,
In theory yes, but the 8 ohm nominal is just that. You really need to know the exact impedance at the crossover point of the two tweeters and add the difference in resistance.
Next stop: Margaritaville
Some of Cal's stuff | Cal Weldon Consulting
Help with modification of QLN crossover Cyberkul Multi-Way 2 3rd October 2008 08:46 PM
Rane Crossover Modification kbasaran Parts 7 18th September 2008 02:01 PM
crossover L-pad modification Theli Multi-Way 7 26th January 2007 05:31 PM
Electronic crossover modification qguy Subwoofers 16 8th January 2007 08:42 PM
electronic crossover modification qguy Multi-Way 5 4th January 2007 11:54 PM
Page generated in 0.05912 seconds (70.25% PHP - 29.75% MySQL) with 10 queries
