My speakers are going to be flush with a wall. I can go at least 40 cm into the wall if necessary. Am I better off with in-wall speakers that seem to be designed to work flush with the wall or would I be better off with a bookshelf design set into the wall. I heard that the crossover might need to change due to the speakers proximity to the wall. Is there anything else I would need to do to the recessed bookshelf spk to make it more suitable.
If the bookshelf protruded 2 or 3cm would that dramatically improve imaging etc? Can anyone recommend a kit, for either in-wall or bookshelf, that would be suitable. Under $800 and suitable for a room 3m x3m Thanks, Dara |
#2 |
Given the two choices I would go with a bookshelf design recessed into the wall. I think you can get more predictable results building a box for a bass driver compared to mounting one in-wall. Of course it depends on the driver as well. If you are looking to go with a ported design make sure you place the port on the front baffle. Placing speakers along a wall results in less baffle step, therefore less compensation will be needed in the crossover.
You can always move a bookshelf speaker later. |
#3 |
Thanks Dave, sound advice!! When you say less baffle step does that mean no roll off towards the higher frequencies at all? What if I have them protruing slightly, say 1 or 2 inches, will I need some baffle step then? Since the room is small the sound will be very subjective to room modes. I intend to measure this. How can I make allowances for (or take advantage of) room modes in the design? Thanks again
#4 |
Oh, and you mentioned that it depends on the driver. In what way?
| Designing for on-wall/near-wall speaker placement | morbo | Multi-Way | 4 | 27th November 2010 05:52 PM |
| Another brick in the wall | Supersasha | Introductions | 6 | 16th February 2008 08:53 PM |
| in-wall/on-wall speaker? (axiom w-22 clone?) | Scott_fx | Multi-Way | 0 | 22nd February 2007 03:08 AM |
| flush mounted in wall studio monitor, any advantages??? | Greggo | Multi-Way | 24 | 2nd December 2005 04:06 AM |
| Opinions on wall to wall subwoofer array | jmiyake | Subwoofers | 35 | 20th July 2003 12:26 AM |
| Page generated in 0.08753 seconds (67.12% PHP - 32.88% MySQL) with 10 queries |
