Old 30th September 2005, 06:51 AM   #1
Question Seas P17REX TL Recommendation
i got a seas Embla kit which uses P17REX... built according to spec of the box from seas and not quite satisfied with the result... wanted to transform that into a TL...
went to www.quarter-wave.com downloaded the mathlab 8 and the TL worksheet... and clueless on how to use it... hopefully anyone knowledgable can recommend some enclosure measurement... my room size is (hxwxd) 3m x 4m x 5m
i know some of the forumer have done a TL with P17REX... hopefully they can share it here
Old 1st October 2005, 12:23 AM   #2
Andy G is offline Andy G  Australia
Andy G's Avatar
The P17REX should work well in my tapered pipe.
http://www.partsexpress.com/projects...pes/pipes.html
This pipe can be straightened and made into a (shudder) rectangular box if you really have to
They will also work well with a series x-o , and with one of the Seas 27Tf series should sound pretty darn good !
Old 1st October 2005, 04:38 AM   #3
pipes... i thought of using that for my next project using a fostex drivers
any TL enclosure recommendation for P17REX ?
Old 2nd October 2005, 04:13 PM   #4
Notax is offline Notax  Montenegro
Notax's Avatar
Default calculation
TL lenght - 175 cm
Fb - 49.1 Hz
constant cross section - 150 cm2
Hawaphon at all wals. Little wool behind bass driver.
x-over 6/12 or 6/18 dB/oct.
This is my calculation. I didn"t work with this unit.
Old 6th October 2005, 07:19 AM   #5
Notax: thanks for the measurement... really appreciate it.
Wanted: Seas W17EX001, Usher 8945P, Seas CA18, or somewhat similar mid-woofer. Spasticteapot Swap Meet 2 7th March 2007 04:06 PM
p17rex , need help ermes Multi-Way 2 2nd June 2006 06:54 AM
Need Seas P17REX Help!! Tenson Multi-Way 10 27th April 2006 04:46 PM
FS: Audax AP170Z0 and Seas P17REX Midbass/Midrange Drivers omarmipi Swap Meet 3 22nd April 2006 11:32 PM
Seas P17REX & Dayton RS180 omarmipi Swap Meet 3 14th March 2006 09:34 PM
Page generated in 0.08734 seconds (68.88% PHP - 31.12% MySQL) with 10 queries
